Fwd: Re: [AG-TECH] Fedora 2
    Michael Miller
    mimiller at ncsa.uiuc.edu
    Thu Jun 17 11:58:08 CDT 2004
Here are Sugree's instructions I used.  Be sure to request a service cert
for your particular machine before firing up a VenueServer.  I had trouble
using a service cert from another machine.
Thanx much to Sugree for setting this up!
Michael Miller
>From: "Sugree Phatanapherom" <sugree at hpcnc.cpe.ku.ac.th>
>To: "Michael Miller" <mimiller at ncsa.uiuc.edu>
>Subject: Re: [AG-TECH] Fedora 2
>Date: Thu, 17 Jun 2004 09:39:10 +0700
>Hi,
>What you want to do is just add 3 lines in /etc/yum.conf.
>--> cut <--
>[accessgrid]
>name=AccessGrid
>baseurl=http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2
>--> cut <--
>Next time you run YUM, it will download all info about accessgrid so you can
>simply install it as below:
># yum groupinstall agtk
I stopped here and then ran the venue client to request/install my cert
I haven't tried the rest of this...
>Note that if you want to create a yum repository, yum-arch command can help
>you. Just change working directory to where you keep all rpms and
>yumgroup.xml (if available) and then run "yum-arch ." to generate headers/*.
>Hope this helps,
> > I love YUM!  But I don't know it well enough to know where to put this
> > stuff.  please let me know what file to edit.
> > Thanx
> > Michael Miller
> > NCSA
> > At 10:09 AM 6/16/2004, you wrote:
> > >[accessgrid]
> > >name=Access Grid
> > >baseurl=http://osl.cpe.ku.ac.th/pub/fedora/linux/core/$releasever
> > >Then simply run:
> > >Good luck,
> > Thanx,
> > Michael Miller
> > System Engineer
> > Visualization Technology Support
> > Computing and Data Management
> > National Center for Supercomputing Applications
> > University of Illinois - UC
> > 217-649-0747
> > "If you're clear in your vision and trust the people in your team with
> > clear objectives, they will invariably do their best to achieve everything
> > desired, and usually deliver everything you could have hoped for and even
> > more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
