[AG-TECH] All-Windows AG nodes?
    Osland, CD (Chris)
    C.D.Osland at rl.ac.uk
    Wed Jun 16 05:06:53 CDT 2004
Apologies to all - and especially M-Audio - about info in my
last e-mail about single-computer all-Windows systems.
The audio cards with balanced I/O that didn't work with Xeon
processors were Echo Audio cards, NOT M-Audio.
Problem caused by working on too many projects simultaneously!
Cheers
Chris Osland
____________________________________________________________________
Chris Osland                                               Office tel: +44
(0) 1235 446565
Digital Media and Access Grid                          Medialab tel: +44 (0)
1235 446459
BIT Department                                     Access Grid room tel: +44
(0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Osland, CD (Chris)
> Sent: 16 June 2004 10:38
> To: 'David E. Bernholdt [bek] 574-3147'; ag-tech at mcs.anl.gov
> Cc: bernholdtde at ornl.gov
> Subject: RE: [AG-TECH] All-Windows AG nodes?
> Don't know about multi-machine all Windows, but single-machine
> all Windows works fine.  Ours are:
> 	twin 2.8 GHz Xeon on Supermicro motherboard (I think)
> 	1 Gb memory
> 	Winnov Videum 4400 VO video capture (4 streams, one card)
> 	Matrox Parhelia 256 Mb display card (we only needed 2 main
> 		displays)
> 	onboard 100 Mbit ethernet
> Spot the non-information about sound.  Here's the story.
> I got M-Audio cards (stereo, balanced I/O) cards but when we
> enabled them, they played back for about half a second and
> then produced a lovely blue screen.  Turns out their cards
> don't work with Xeon processors - the memory access mechanism
> is subtly different from Pentiums, and the M-Audio cards work
> with Pentiums and Athlons, but not Xeons.
> In a panic (days to go before VERY high profile demo - UK
> Minister for Science!) I found that the onboard AC97 audio
> chipset actually was full duplex, so added a balanced-unbalanced
> interface (we use Sonifex, but any will do) and a couple of
> stereo mini-jack to twin phono leads and we were away.
> I have now found that E-Mu 1212m cards do support Xeons
> (including twin Xeons) and so, as they are cheaper than the
> bal-unbal interface and save 1U rack space, will try those in my
> next nodes.
> On the display front, we are about to try the Matrox QID which
> has, at long last, surfaced - 4 outputs from a single PCI-X or
> AGP slot.
> Hope that helps
> Chris
> Chris Osland
> Office tel: +44
> (0) 1235 446565
> 1235 446459
> Grid room tel: +44
> (0) 1235 445666
>       Fax: +44
> (0) 1235 445597
> use of the
> on it or show
> it to anyone else,
> > Behalf Of David E. Bernholdt [bek] 574-3147
> > Sent: 15 June 2004 18:19
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] All-Windows AG nodes?
> > Since Windows PIGs work okay, I assume a multi-machine
> all-Windows AG
> > node configuration (as opposed to Windows for display and Linux for
> > capture) works okay, but can anyone confirm that they're actually
> > using such a setup?  Are there any problems with multiple Hauppague
> > video capture cards under Windows?  Would anyone have reservations
> > about going with such a setup?
> > Thanks
> > David E. Bernholdt                   |   Email:
> > Oak Ridge National Laboratory        |   Phone: +1 (865)
> 574 3147
> > http://www.csm.ornl.gov/~bernhold/   |   Fax:   +1 (865) 576 5491
