[AG-TECH] AG 2.2 ports
    Ivan R. Judson
    judson at mcs.anl.gov
    Mon Jun 14 09:08:46 CDT 2004
Hey Michael,
The change in 2.2 was that the personal node used to start the services
separately, on 3 different SOAP servers, running on ports 11000, 12000,
and one dynamic port for the venue client.
Now when run in personal node mode (--personalNode) the services all run
from a single SOAP server on port 11000, unless you specify a port on the
command line.
The net result is a major performance gain and simpler configuration. So
the answer to your question is everything is running on 11000.
--Ivan
On Mon, 14 Jun 2004, Michael Miller wrote:
> I know there was a change ins the way the Node Service and Service Manager
> ports are assigned.  Can someone enumerate the changes?  I know the local
> service manager on a pig is now on 11000, but where is the node service?
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve everything
> desired, and usually deliver everything you could have hoped for and even
> more." -Paul Debevec
