[AG-TECH] Problems while installing AGkt2.2 from source on a Debian
    Joseph
    joseph at cs.usyd.edu.au
    Mon Jun  7 04:38:03 CDT 2004
Hello
I've sent the requested information directly to Tom and the two others
Debian packagers. It's too big to go on the mailing list I think. So if
someone is interested, just let me know.
Thanks again for your help
Cheers,
	Joseph
On Mon, 07 Jun 2004 01:53:13 -0500, Thomas D. Uram <turam at mcs.anl.gov>
wrote:
> Hi Joseph:
> For some of the problems you've run into, we'll have to see more detail
> to try to help. Could you create a log of the build using 'script' or
> something similar, and send the entire build log?  It will be long, so
> you might want to send it to ag-mcs at mcs.anl.gov instead of the ag-tech
> list; please also include at least the other Debian packagers (<Jason
> Hill> jahill at scl.ameslab.gov, dgolden at cp.dias.ie), too, so they can help
> if possible.
> It's not clear to me from the error output alone why ssl.h is not being
> found during the openssl build.  Maybe the reason for this, too, will be
> more clear from the more detailed log result.  Please also send details
> about what directories have been created in the timestamped dist
> directory.
> As for rpms:  I expect that for debian the result will debian packages,
> not rpms.  The details of creating these packages will likely be
> captured in a packaging/linux/debian/BuildPackage.py script.  I don't
> know about packaging for debian, so unfortunately can't help much there.
>   I can say that the script will likey perform many of the same tasks as
> the rpm/BuildPackage.py script.
> Thanks again for your work packaging for debian.
> Tom
> Joseph wrote:
>> Hello
>> As I need to install AGtk2.2 on a Debian, I've worked from the source
>> tarball. To know how to do, I've followed the instructions gently given
>> by Thomas D. Uram for the beta version in a doc called
>> AG-Linux-Build-HOWTO.rtf (which is quite big so I don't attach it to
>> this mail).
>> However, when I execute python BuildSnapshot.py --no-check-out
>> --sourcedir=/sourcedir in the ccessGrid/packaging directory, I have
>> some troubles during the script.
>> Firstly, there are a lot of errors in the files in the src/crypto
>> directory.
>> Then, a failure happens because of an "ImportError: No module named
>> pyGlobus".
>> Finally, of course, there is a problem with the rpm construction.
>> However, the script produces an
>> AccessGrid-2.2-Snapshot-date_hour.tar.gz and creates a dist-date_hour
>> repertory. I don't have, though, a AccessGrid-2.2-date_hour.tar.gz, the
>> binary file.
>> BTW, the error output is pasted at the end of this mail. I didn't paste
>> the standard output since it's too big.
>> I didn't try to solve the firt trouble, because it's some parse errors
>> and stuff like this (so trouble with the code itself most probably) and
>> it didn't seem to be important for the time.
>> I've tried to solve the second point. In the AG-Linux-Build-HOWTO.rtf,
>> there was no mention of pyGlobus, but I thought it might finally be
>> needed. So I went to pyGlobus website and ... found there is no version
>> of pyGlobus for the GlobusToolkit 3.0.2 (the one used in the
>> AG-Linux-Build-HOWTO.rtf).
>> I've tried with pyGlobus for Globus2.4 then 3.2 but it wasn't a success
>> (for the 2.4 one it's because I have no repertory for Globus, since
>> Globus3.0.2's install doesn't create one, for the other one the
>> installation went ok but the AccessGrid intall still fails). I also set
>> the PYTHONPATH but without success.
>> So I don't know what to do. I have also noticed that some pyGlobus
>> files and repertories are made during the installation of AccessGrid by
>> the installation script itself, so I wonder if there is a trouble
>> during the installation...
>> For the rpm, AccessGrid-2.2-Snapshot-date_hour.src.tar.gz and the
>> dist-date_hour repertory, I don't know what to do with them in order to
>> install AccessGrid. For sure, I don't want some rpm but some binary or
>> an installation from the source (to be able to do some *.deb for the
>> debian packaging system).
>> However, I found nothing close to a binary or an installation script in
>> the AccessGrid-2.2-Snapshot-date_hour.src.tar.gz and the dist-date_hour
>> repertory. I don't neither have the binary tar.gz file, so I don't know
>> what to do to install AccessGrid.
>> I hope you don't mind my questions and you will be able to help me !
>> BTW, I'm quite new to linux and linux packaging, so I may lack some
>> basic knowledges, sorry.
>> Cheers,
>>      Joseph
>> ps : the error output :
>> sys:1: DeprecationWarning: Non-ASCII character '\xc3' in file setup.py
>> on line 87, but no encoding declared; see http://www.python.org/
>> peps/pep-0263.html for details
>> In file included from src/crypto/crypto.h:17,
>>                  from src/crypto/pkcs7.c:12:
>> src/crypto/x509.h:17:25: openssl/ssl.h: No such file or directory
>> src/crypto/x509.h:27: error: parse error before "X509"
>> src/crypto/x509.h:27: warning: no semicolon at end of struct or union
>> src/crypto/x509.h:29: error: parse error before '}' token
>> src/crypto/x509.h:29: warning: type defaults to `int' in declaration of
>> `crypto_X509Obj'
>> src/crypto/x509.h:29: warning: data definition has no type or storage
>> class
>> In file included from src/crypto/crypto.h:18,
>> src/crypto/x509name.h:22:25: openssl/ssl.h: No such file or directory
>> src/crypto/x509name.h:32: error: parse error before "X509_NAME"
>> src/crypto/x509name.h:32: warning: no semicolon at end of struct or
>> union
>> src/crypto/x509name.h:35: error: parse error before '}' token
>> src/crypto/x509name.h:35: warning: type defaults to `int' in
>> declaration of `crypto_X509NameObj'
>> src/crypto/x509name.h:35: warning: data definition has no type or
>> storage class
>> In file included from src/crypto/crypto.h:19,
>> src/crypto/x509store.h:15:25: openssl/ssl.h: No such file or directory
>> src/crypto/x509store.h:25: error: parse error before "X509_STORE"
>> src/crypto/x509store.h:25: warning: no semicolon at end of struct or
>> union
>> src/crypto/x509store.h:27: error: parse error before '}' token
>> src/crypto/x509store.h:27: warning: type defaults to `int' in
>> declaration of `crypto_X509StoreObj'
>> src/crypto/x509store.h:27: warning: data definition has no type or
>> storage class
>> In file included from src/crypto/crypto.h:20,
>> src/crypto/x509req.h:15:25: openssl/ssl.h: No such file or directory
>> src/crypto/x509req.h:25: error: parse error before "X509_REQ"
>> src/crypto/x509req.h:25: warning: no semicolon at end of struct or union
>> src/crypto/x509req.h:27: error: parse error before '}' token
>> src/crypto/x509req.h:27: warning: type defaults to `int' in declaration
>> of `crypto_X509ReqObj'
>> src/crypto/x509req.h:27: warning: data definition has no type or
>> storage class
>> In file included from src/crypto/crypto.h:21,
>> src/crypto/pkey.h:22: error: parse error before "EVP_PKEY"
>> src/crypto/pkey.h:22: warning: no semicolon at end of struct or union
>> src/crypto/pkey.h:24: error: parse error before '}' token
>> src/crypto/pkey.h:24: warning: type defaults to `int' in declaration of
>> `crypto_PKeyObj'
>> src/crypto/pkey.h:24: warning: data definition has no type or storage
>> class
>> In file included from src/crypto/crypto.h:22,
>> src/crypto/x509ext.h:15:25: openssl/ssl.h: No such file or directory
>> src/crypto/x509ext.h:16:28: openssl/x509v3.h: No such file or directory
>> src/crypto/x509ext.h:27: error: parse error before "X509_EXTENSION"
>> src/crypto/x509ext.h:27: warning: no semicolon at end of struct or union
>> src/crypto/x509ext.h:29: error: parse error before '}' token
>> src/crypto/x509ext.h:29: warning: type defaults to `int' in declaration
>> of `crypto_X509ExtensionObj'
>> src/crypto/x509ext.h:29: warning: data definition has no type or
>> storage class
>> In file included from src/crypto/crypto.h:23,
>> src/crypto/pkcs7.h:15:27: openssl/pkcs7.h: No such file or directory
>> src/crypto/pkcs7.h:25: error: parse error before "PKCS7"
>> src/crypto/pkcs7.h:25: warning: no semicolon at end of struct or union
>> src/crypto/pkcs7.h:27: error: parse error before '}' token
>> src/crypto/pkcs7.h:27: warning: type defaults to `int' in declaration
>> of `crypto_PKCS7Obj'
>> src/crypto/pkcs7.h:27: warning: data definition has no type or storage
>> class
>> In file included from src/crypto/crypto.h:24,
>> src/crypto/pkcs12.h:14:28: openssl/pkcs12.h: No such file or directory
>> src/crypto/pkcs12.h:15:26: openssl/asn1.h: No such file or directory
>> In file included from src/crypto/crypto.h:25,
>> src/util.h:17:25: openssl/err.h: No such file or directory
>> In file included from src/crypto/pkcs7.c:12:
>> src/crypto/crypto.h:70: error: parse error before '*' token
>> src/crypto/crypto.h:70: warning: type defaults to `int' in declaration
>> of `crypto_X509_New'
>> src/crypto/crypto.h:70: warning: function declaration isn't a prototype
>> src/crypto/crypto.h:70: warning: data definition has no type or storage
>> class
>> src/crypto/crypto.h:71: error: parse error before '*' token
>> src/crypto/crypto.h:71: warning: type defaults to `int' in declaration
>> of `crypto_X509Name_New'
>> src/crypto/crypto.h:71: warning: function declaration isn't a prototype
>> src/crypto/crypto.h:71: warning: data definition has no type or storage
>> class
>> src/crypto/crypto.h:72: error: parse error before '*' token
>> src/crypto/crypto.h:72: warning: type defaults to `int' in declaration
>> of `crypto_X509Req_New'
>> src/crypto/crypto.h:72: warning: function declaration isn't a prototype
>> src/crypto/crypto.h:72: warning: data definition has no type or storage
>> class
>> src/crypto/crypto.h:73: error: parse error before '*' token
>> src/crypto/crypto.h:73: warning: type defaults to `int' in declaration
>> of `crypto_X509Store_New'
>> src/crypto/crypto.h:73: warning: function declaration isn't a prototype
>> src/crypto/crypto.h:73: warning: data definition has no type or storage
>> class
>> src/crypto/crypto.h:74: error: parse error before '*' token
>> src/crypto/crypto.h:74: warning: type defaults to `int' in declaration
>> of `crypto_PKey_New'
>> src/crypto/crypto.h:74: warning: function declaration isn't a prototype
>> src/crypto/crypto.h:74: warning: data definition has no type or storage
>> class
>> src/crypto/crypto.h:75: error: parse error before '*' token
>> src/crypto/crypto.h:75: warning: type defaults to `int' in declaration
>> of `crypto_X509Extension_New'
>> src/crypto/crypto.h:75: warning: data definition has no type or storage
>> class
>> src/crypto/crypto.h:76: error: parse error before '*' token
>> src/crypto/crypto.h:76: warning: type defaults to `int' in declaration
>> of `crypto_PKCS7_New'
>> src/crypto/crypto.h:76: warning: function declaration isn't a prototype
>> src/crypto/crypto.h:76: warning: data definition has no type or storage
>> class
>> src/crypto/pkcs7.c:25: error: parse error before '*' token
>> src/crypto/pkcs7.c:26: warning: function declaration isn't a prototype
>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_signed':
>> src/crypto/pkcs7.c:27: error: `args' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:27: error: (Each undeclared identifier is reported
>> only once
>> src/crypto/pkcs7.c:27: error: for each function it appears in.)
>> src/crypto/pkcs7.c:30: warning: implicit declaration of function
>> `PKCS7_type_is_signed'
>> src/crypto/pkcs7.c:30: error: `self' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c: At top level:
>> src/crypto/pkcs7.c:45: error: parse error before '*' token
>> src/crypto/pkcs7.c:46: warning: function declaration isn't a prototype
>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_enveloped':
>> src/crypto/pkcs7.c:47: error: `args' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:50: warning: implicit declaration of function
>> `PKCS7_type_is_enveloped'
>> src/crypto/pkcs7.c:50: error: `self' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:65: error: parse error before '*' token
>> src/crypto/pkcs7.c:66: warning: function declaration isn't a prototype
>> `crypto_PKCS7_type_is_signedAndEnveloped':
>> src/crypto/pkcs7.c:67: error: `args' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:70: warning: implicit declaration of function
>> `PKCS7_type_is_signedAndEnveloped'
>> src/crypto/pkcs7.c:70: error: `self' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:85: error: parse error before '*' token
>> src/crypto/pkcs7.c:86: warning: function declaration isn't a prototype
>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_data':
>> src/crypto/pkcs7.c:87: error: `args' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:90: warning: implicit declaration of function
>> `PKCS7_type_is_data'
>> src/crypto/pkcs7.c:90: error: `self' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:105: error: parse error before '*' token
>> src/crypto/pkcs7.c:106: warning: function declaration isn't a prototype
>> src/crypto/pkcs7.c: In function `crypto_PKCS7_get_type_name':
>> src/crypto/pkcs7.c:107: error: `args' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:113: warning: implicit declaration of function
>> `OBJ_nid2sn'
>> `OBJ_obj2nid'
>> src/crypto/pkcs7.c:113: error: `self' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:113: warning: passing arg 1 of `PyString_FromString'
>> makes pointer from integer without a cast
>> src/crypto/pkcs7.c:143: error: parse error before '*' token
>> src/crypto/pkcs7.c:144: error: parse error before '*' token
>> src/crypto/pkcs7.c:145: warning: return type defaults to `int'
>> src/crypto/pkcs7.c:145: warning: function declaration isn't a prototype
>> src/crypto/pkcs7.c: In function `crypto_PKCS7_New':
>> src/crypto/pkcs7.c:146: error: `self' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:148: error: parse error before ')' token
>> src/crypto/pkcs7.c:153: error: `pkcs7' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:166: error: parse error before '*' token
>> src/crypto/pkcs7.c:167: warning: function declaration isn't a prototype
>> src/crypto/pkcs7.c: In function `crypto_PKCS7_dealloc':
>> src/crypto/pkcs7.c:169: error: `self' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:170: warning: implicit declaration of function
>> `PKCS7_free'
>> src/crypto/pkcs7.c:184: error: parse error before '*' token
>> src/crypto/pkcs7.c:185: warning: function declaration isn't a prototype
>> src/crypto/pkcs7.c: In function `crypto_PKCS7_getattr':
>> src/crypto/pkcs7.c:186: error: `self' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:186: error: `name' undeclared (first use in this
>> function)
>> src/crypto/pkcs7.c:14: warning: `CVSid' defined but not used
>> error: command 'gcc' failed with exit status 1
>> `crypto_X509Obj'
>> class
>> union
>> storage class
>> union
>> storage class
>> storage class
>> `crypto_PKeyObj'
>> class
>> storage class
>> class
>> class
>> class
>> class
>> class
>> class
>> class
>> class
>> function)
>> only once
>> function)
>> function)
>> function)
>> function)
>> function)
>> function)
>> function)
>> function)
>> `OBJ_nid2sn'
>> `OBJ_obj2nid'
>> function)
>> function)
>> function)
>> function)
>> `PKCS7_free'
>> function)
>> function)
>> Traceback (most recent call last):
>>   File "test_dist.py", line 213, in ?
>>     for module in map(__import__, modules_to_test):
>>   File "/var/tmp/build/AccessGrid/tests/unittest_ClientProfile.py",
>> line 20, in ?
>>     from AccessGrid.Platform.Config import SystemConfig
>>   File
>> "/var/tmp/build/dist-20040603_193542/lib/python2.3/site-packages/AccessGrid/Platform/__init__.py",
>> line 59, in ?
>>     from AccessGrid.Platform.unix import Config as Config
>>   File
>> "/var/tmp/build/dist-20040603_193542/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
>> line 21, in ?
>>     from pyGlobus import security
>> ImportError: No module named pyGlobus
>> BuildPackage.py:45: RuntimeWarning: tmpnam is a potential security risk
>> to your program
>>   TmpDir = os.tmpnam()
>> rpm: To install rpm packages on Debian systems, use alien. See
>> README.Debian.
>> error: cannot open Packages index using db3 - No such file or directory
>> (2)
>> error: cannot open rpm database in /var/lib/rpm
>> cp: cannot stat
>> `/usr/src/redhat/RPMS/i386/globus-accessgrid-2.4-1.i386.rpm': No such
>> file or directory
>> tar:
>> /usr/src/redhat/SOURCES/AccessGrid-2.2-Snapshot_20040603_193542.tar.gz:
>> Cannot open: No such file or directory
>> tar: Error is not recoverable: exiting now
>> to your program
>> README.Debian.
>> (2)
>> cp: cannot stat
>> file or directory
>> tar:
