[AG-TECH] Problems while installing AGkt2.2 from source on a Debian
    Joseph
    joseph at cs.usyd.edu.au
    Sun Jun  6 18:33:39 CDT 2004
Hello
As I need to install AGtk2.2 on a Debian, I've worked from the source
tarball. To know how to do, I've followed the instructions gently given by
Thomas D. Uram for the beta version in a doc called
AG-Linux-Build-HOWTO.rtf (which is quite big so I don't attach it to this
mail).
However, when I execute python BuildSnapshot.py --no-check-out
--sourcedir=/sourcedir in the ccessGrid/packaging directory, I have some
troubles during the script.
Firstly, there are a lot of errors in the files in the src/crypto
directory.
Then, a failure happens because of an "ImportError: No module named
pyGlobus".
Finally, of course, there is a problem with the rpm construction.
However, the script produces an AccessGrid-2.2-Snapshot-date_hour.tar.gz
and creates a dist-date_hour repertory. I don't have, though, a
AccessGrid-2.2-date_hour.tar.gz, the binary file.
BTW, the error output is pasted at the end of this mail. I didn't paste
the standard output since it's too big.
I didn't try to solve the firt trouble, because it's some parse errors and
stuff like this (so trouble with the code itself most probably) and it
didn't seem to be important for the time.
I've tried to solve the second point. In the AG-Linux-Build-HOWTO.rtf,
there was no mention of pyGlobus, but I thought it might finally be
needed. So I went to pyGlobus website and ... found there is no version of
pyGlobus for the GlobusToolkit 3.0.2 (the one used in the
AG-Linux-Build-HOWTO.rtf).
I've tried with pyGlobus for Globus2.4 then 3.2 but it wasn't a success
(for the 2.4 one it's because I have no repertory for Globus, since
Globus3.0.2's install doesn't create one, for the other one the
installation went ok but the AccessGrid intall still fails). I also set
the PYTHONPATH but without success.
So I don't know what to do. I have also noticed that some pyGlobus files
and repertories are made during the installation of AccessGrid by the
installation script itself, so I wonder if there is a trouble during the
installation...
For the rpm, AccessGrid-2.2-Snapshot-date_hour.src.tar.gz and the
dist-date_hour repertory, I don't know what to do with them in order to
install AccessGrid. For sure, I don't want some rpm but some binary or an
installation from the source (to be able to do some *.deb for the debian
packaging system).
However, I found nothing close to a binary or an installation script in
the AccessGrid-2.2-Snapshot-date_hour.src.tar.gz and the dist-date_hour
repertory. I don't neither have the binary tar.gz file, so I don't know
what to do to install AccessGrid.
I hope you don't mind my questions and you will be able to help me ! BTW,
I'm quite new to linux and linux packaging, so I may lack some basic
knowledges, sorry.
Cheers,
      Joseph
ps : the error output :
sys:1: DeprecationWarning: Non-ASCII character '\xc3' in file setup.py on
line 87, but no encoding declared; see http://www.python.org/
peps/pep-0263.html for details
In file included from src/crypto/crypto.h:17,
                  from src/crypto/pkcs7.c:12:
src/crypto/x509.h:17:25: openssl/ssl.h: No such file or directory
src/crypto/x509.h:27: error: parse error before "X509"
src/crypto/x509.h:27: warning: no semicolon at end of struct or union
src/crypto/x509.h:29: error: parse error before '}' token
src/crypto/x509.h:29: warning: type defaults to `int' in declaration of
`crypto_X509Obj'
src/crypto/x509.h:29: warning: data definition has no type or storage class
In file included from src/crypto/crypto.h:18,
src/crypto/x509name.h:22:25: openssl/ssl.h: No such file or directory
src/crypto/x509name.h:32: error: parse error before "X509_NAME"
src/crypto/x509name.h:32: warning: no semicolon at end of struct or union
src/crypto/x509name.h:35: error: parse error before '}' token
src/crypto/x509name.h:35: warning: type defaults to `int' in declaration
of `crypto_X509NameObj'
src/crypto/x509name.h:35: warning: data definition has no type or storage
class
In file included from src/crypto/crypto.h:19,
src/crypto/x509store.h:15:25: openssl/ssl.h: No such file or directory
src/crypto/x509store.h:25: error: parse error before "X509_STORE"
src/crypto/x509store.h:25: warning: no semicolon at end of struct or union
src/crypto/x509store.h:27: error: parse error before '}' token
src/crypto/x509store.h:27: warning: type defaults to `int' in declaration
of `crypto_X509StoreObj'
src/crypto/x509store.h:27: warning: data definition has no type or storage
class
In file included from src/crypto/crypto.h:20,
src/crypto/x509req.h:15:25: openssl/ssl.h: No such file or directory
src/crypto/x509req.h:25: error: parse error before "X509_REQ"
src/crypto/x509req.h:25: warning: no semicolon at end of struct or union
src/crypto/x509req.h:27: error: parse error before '}' token
src/crypto/x509req.h:27: warning: type defaults to `int' in declaration of
`crypto_X509ReqObj'
src/crypto/x509req.h:27: warning: data definition has no type or storage
class
In file included from src/crypto/crypto.h:21,
src/crypto/pkey.h:22: error: parse error before "EVP_PKEY"
src/crypto/pkey.h:22: warning: no semicolon at end of struct or union
src/crypto/pkey.h:24: error: parse error before '}' token
src/crypto/pkey.h:24: warning: type defaults to `int' in declaration of
`crypto_PKeyObj'
src/crypto/pkey.h:24: warning: data definition has no type or storage class
In file included from src/crypto/crypto.h:22,
src/crypto/x509ext.h:15:25: openssl/ssl.h: No such file or directory
src/crypto/x509ext.h:16:28: openssl/x509v3.h: No such file or directory
src/crypto/x509ext.h:27: error: parse error before "X509_EXTENSION"
src/crypto/x509ext.h:27: warning: no semicolon at end of struct or union
src/crypto/x509ext.h:29: error: parse error before '}' token
src/crypto/x509ext.h:29: warning: type defaults to `int' in declaration of
`crypto_X509ExtensionObj'
src/crypto/x509ext.h:29: warning: data definition has no type or storage
class
In file included from src/crypto/crypto.h:23,
src/crypto/pkcs7.h:15:27: openssl/pkcs7.h: No such file or directory
src/crypto/pkcs7.h:25: error: parse error before "PKCS7"
src/crypto/pkcs7.h:25: warning: no semicolon at end of struct or union
src/crypto/pkcs7.h:27: error: parse error before '}' token
src/crypto/pkcs7.h:27: warning: type defaults to `int' in declaration of
`crypto_PKCS7Obj'
src/crypto/pkcs7.h:27: warning: data definition has no type or storage
class
In file included from src/crypto/crypto.h:24,
src/crypto/pkcs12.h:14:28: openssl/pkcs12.h: No such file or directory
src/crypto/pkcs12.h:15:26: openssl/asn1.h: No such file or directory
In file included from src/crypto/crypto.h:25,
src/util.h:17:25: openssl/err.h: No such file or directory
In file included from src/crypto/pkcs7.c:12:
src/crypto/crypto.h:70: error: parse error before '*' token
src/crypto/crypto.h:70: warning: type defaults to `int' in declaration of
`crypto_X509_New'
src/crypto/crypto.h:70: warning: function declaration isn't a prototype
src/crypto/crypto.h:70: warning: data definition has no type or storage
class
src/crypto/crypto.h:71: error: parse error before '*' token
src/crypto/crypto.h:71: warning: type defaults to `int' in declaration of
`crypto_X509Name_New'
src/crypto/crypto.h:71: warning: function declaration isn't a prototype
src/crypto/crypto.h:71: warning: data definition has no type or storage
class
src/crypto/crypto.h:72: error: parse error before '*' token
src/crypto/crypto.h:72: warning: type defaults to `int' in declaration of
`crypto_X509Req_New'
src/crypto/crypto.h:72: warning: function declaration isn't a prototype
src/crypto/crypto.h:72: warning: data definition has no type or storage
class
src/crypto/crypto.h:73: error: parse error before '*' token
src/crypto/crypto.h:73: warning: type defaults to `int' in declaration of
`crypto_X509Store_New'
src/crypto/crypto.h:73: warning: function declaration isn't a prototype
src/crypto/crypto.h:73: warning: data definition has no type or storage
class
src/crypto/crypto.h:74: error: parse error before '*' token
src/crypto/crypto.h:74: warning: type defaults to `int' in declaration of
`crypto_PKey_New'
src/crypto/crypto.h:74: warning: function declaration isn't a prototype
src/crypto/crypto.h:74: warning: data definition has no type or storage
class
src/crypto/crypto.h:75: error: parse error before '*' token
src/crypto/crypto.h:75: warning: type defaults to `int' in declaration of
`crypto_X509Extension_New'
src/crypto/crypto.h:75: warning: data definition has no type or storage
class
src/crypto/crypto.h:76: error: parse error before '*' token
src/crypto/crypto.h:76: warning: type defaults to `int' in declaration of
`crypto_PKCS7_New'
src/crypto/crypto.h:76: warning: function declaration isn't a prototype
src/crypto/crypto.h:76: warning: data definition has no type or storage
class
src/crypto/pkcs7.c:25: error: parse error before '*' token
src/crypto/pkcs7.c:26: warning: function declaration isn't a prototype
src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_signed':
src/crypto/pkcs7.c:27: error: `args' undeclared (first use in this
function)
src/crypto/pkcs7.c:27: error: (Each undeclared identifier is reported only
once
src/crypto/pkcs7.c:27: error: for each function it appears in.)
src/crypto/pkcs7.c:30: warning: implicit declaration of function
`PKCS7_type_is_signed'
src/crypto/pkcs7.c:30: error: `self' undeclared (first use in this
function)
src/crypto/pkcs7.c: At top level:
src/crypto/pkcs7.c:45: error: parse error before '*' token
src/crypto/pkcs7.c:46: warning: function declaration isn't a prototype
src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_enveloped':
src/crypto/pkcs7.c:47: error: `args' undeclared (first use in this
function)
src/crypto/pkcs7.c:50: warning: implicit declaration of function
`PKCS7_type_is_enveloped'
src/crypto/pkcs7.c:50: error: `self' undeclared (first use in this
function)
src/crypto/pkcs7.c:65: error: parse error before '*' token
src/crypto/pkcs7.c:66: warning: function declaration isn't a prototype
src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_signedAndEnveloped':
src/crypto/pkcs7.c:67: error: `args' undeclared (first use in this
function)
src/crypto/pkcs7.c:70: warning: implicit declaration of function
`PKCS7_type_is_signedAndEnveloped'
src/crypto/pkcs7.c:70: error: `self' undeclared (first use in this
function)
src/crypto/pkcs7.c:85: error: parse error before '*' token
src/crypto/pkcs7.c:86: warning: function declaration isn't a prototype
src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_data':
src/crypto/pkcs7.c:87: error: `args' undeclared (first use in this
function)
src/crypto/pkcs7.c:90: warning: implicit declaration of function
`PKCS7_type_is_data'
src/crypto/pkcs7.c:90: error: `self' undeclared (first use in this
function)
src/crypto/pkcs7.c:105: error: parse error before '*' token
src/crypto/pkcs7.c:106: warning: function declaration isn't a prototype
src/crypto/pkcs7.c: In function `crypto_PKCS7_get_type_name':
src/crypto/pkcs7.c:107: error: `args' undeclared (first use in this
function)
src/crypto/pkcs7.c:113: warning: implicit declaration of function
`OBJ_nid2sn'
`OBJ_obj2nid'
src/crypto/pkcs7.c:113: error: `self' undeclared (first use in this
function)
src/crypto/pkcs7.c:113: warning: passing arg 1 of `PyString_FromString'
makes pointer from integer without a cast
src/crypto/pkcs7.c:143: error: parse error before '*' token
src/crypto/pkcs7.c:144: error: parse error before '*' token
src/crypto/pkcs7.c:145: warning: return type defaults to `int'
src/crypto/pkcs7.c:145: warning: function declaration isn't a prototype
src/crypto/pkcs7.c: In function `crypto_PKCS7_New':
src/crypto/pkcs7.c:146: error: `self' undeclared (first use in this
function)
src/crypto/pkcs7.c:148: error: parse error before ')' token
src/crypto/pkcs7.c:153: error: `pkcs7' undeclared (first use in this
function)
src/crypto/pkcs7.c:166: error: parse error before '*' token
src/crypto/pkcs7.c:167: warning: function declaration isn't a prototype
src/crypto/pkcs7.c: In function `crypto_PKCS7_dealloc':
src/crypto/pkcs7.c:169: error: `self' undeclared (first use in this
function)
src/crypto/pkcs7.c:170: warning: implicit declaration of function
`PKCS7_free'
src/crypto/pkcs7.c:184: error: parse error before '*' token
src/crypto/pkcs7.c:185: warning: function declaration isn't a prototype
src/crypto/pkcs7.c: In function `crypto_PKCS7_getattr':
src/crypto/pkcs7.c:186: error: `self' undeclared (first use in this
function)
src/crypto/pkcs7.c:186: error: `name' undeclared (first use in this
function)
src/crypto/pkcs7.c:14: warning: `CVSid' defined but not used
error: command 'gcc' failed with exit status 1
`crypto_X509Obj'
class
class
`crypto_X509ReqObj'
class
`crypto_PKeyObj'
class
`crypto_PKCS7Obj'
class
`crypto_X509_New'
class
class
class
class
`crypto_PKey_New'
class
class
`crypto_PKCS7_New'
class
function)
once
function)
function)
function)
function)
function)
function)
function)
function)
`OBJ_nid2sn'
`OBJ_obj2nid'
function)
function)
function)
function)
`PKCS7_free'
function)
function)
Traceback (most recent call last):
   File "test_dist.py", line 213, in ?
     for module in map(__import__, modules_to_test):
   File "/var/tmp/build/AccessGrid/tests/unittest_ClientProfile.py", line
20, in ?
     from AccessGrid.Platform.Config import SystemConfig
   File
"/var/tmp/build/dist-20040603_193542/lib/python2.3/site-packages/AccessGrid/Platform/__init__.py",
line 59, in ?
     from AccessGrid.Platform.unix import Config as Config
   File
"/var/tmp/build/dist-20040603_193542/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
line 21, in ?
     from pyGlobus import security
ImportError: No module named pyGlobus
BuildPackage.py:45: RuntimeWarning: tmpnam is a potential security risk to
your program
   TmpDir = os.tmpnam()
rpm: To install rpm packages on Debian systems, use alien. See
README.Debian.
error: cannot open Packages index using db3 - No such file or directory (2)
error: cannot open rpm database in /var/lib/rpm
cp: cannot stat
`/usr/src/redhat/RPMS/i386/globus-accessgrid-2.4-1.i386.rpm': No such file
or directory
tar:
/usr/src/redhat/SOURCES/AccessGrid-2.2-Snapshot_20040603_193542.tar.gz:
Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
your program
README.Debian.
cp: cannot stat
or directory
tar:
