[AG-TECH] AG2.2 Update Available for Multi-machine, Multi-operating system nodes
    Thomas D. Uram
    turam at mcs.anl.gov
    Fri Jun  4 14:45:43 CDT 2004
> Note: If you are running the Access Grid Toolkit 2.2 on a single-machine
> node, or on a multi-machine node where all machines run the same
> operating system, you can ignore this message.
> The recent release of the Access Grid Toolkit, version 2.2, requires an
> update to service packages for audio and video on multi-machine nodes.
The update is now available at the following location:
http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.2/updates/AGTk22_ServiceUpdate.zip
This package includes service updates for the 2.2 release of the Access
Grid Toolkit.  These updates are required for Access Grid nodes that
consist of multiple machines running multiple operating systems; for
example, a node that consists of a Windows PC and a Linux PC.
The update can be installed as follows:
1. Unzip all files to a directory
    The files include install.py and several node service packages
    (.zip); you do not need to unpack these.
2. As an administrator, execute 'install.py'
This will copy the updated service packages to the proper location in
your Access Grid software installation.
The AG Team
