[AG-TECH] Cant run AG2.2 applications...
Natalia Costas Lago
natalia at cesga.es
Wed Jun 2 06:26:14 CDT 2004
I'm having trouble trying to execute the AG2.2 Venue Client (1st June final
version) under Linux (don't know about Windows version yet). Maybe I haven't
deleted the prior version correctly. Can someone tell me how to delete
AG2.1.2 and/or AG2.2 (beta) releases? (I did rpm -i of the components I've
found.
The error I get is the next:
[ag at agcontrol AccessGrid-2.2-6]$ VenueClient.py
Traceback (most recent call last):
File "/usr/bin/VenueClient.py", line 107, in ?
main()
File "/usr/bin/VenueClient.py", line 49, in main
app = WXGUIApplication()
File "/usr/lib/python2.2/site-packages/AccessGrid/Toolkit.py", line 405,
in __init__
[ ("agpm.py", agpmCmd, "open") ] )
File
"/usr/lib/python2.2/site-packages/AccessGrid/Platform/unix/Config.py", line
845, in RegisterMimeType
gnomeAppInfo="""
TypeError: strip() takes no arguments (1 given)
Thankx in advance.
Kind regards,
Natalia.
PS: I use KDE, in case it is a relevant information.
PS2: I've deleted /etc/AccessGrid and /home/ag/.AccessGrid prior to AG2.2
(1st June) installation.
> The Access Grid Toolkit 2.2 is available for download at:
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.2/index.ht> ml
> It is strongly recommended that you remove previous versions of the
> Access Grid Toolkit before installing the 2.2 software. While the 2.2
> final software should co-exist with previous installations cleanly, the
> alpha and beta are known to cause problems.
> This release includes major usability and stability improvements.
> Highlights include:
> - Updated to Python 2.3 (on windows)
> - Update to the latest SOAPpy
> - Update to newer pyGlobus and Globus Toolkit (on linux)
> - Streamlined Certificate Management User Interfaces
> - Support for Service Certificates
> - Support for an anonymous certificate service
> - New Node Service Packaging, which supports more flexible Node
> Services - Shared Applications Developers Tools, Examples and a
> Programmers Manual - A Venue Client Control Interface (so the Venue
> Client can be
> programmatically controlled)
> - Usage logging in the Venue Server
> - Automatic reconnection for the Venue Client
> - Venue Server significantly stabilized, memory leaks plugged.
> - Double clicking app packages will install them automatically.
> Known Issues:
> - Venue Management Tool rewrites address upon connection, after it has
> connected to the local server.
> -Detection of some video devices on windows is not working, anything
> that maps to the video for windows device should work.
> For more information on this release see the official release page.
> As always, feedback is desired. Please file bug reports, feature
> requests, or enhancements via the Access Grid Bugzilla pages
> (http://bugzilla.mcs.anl.gov/acucessgrid) or via the ag-tech mailing
> list (mailto:ag-tech at mcs.anl.gov).
> Thanks,
> The AG Team
Natalia Costas Lago
mailto: natalia at cesga.es
Centro de Supercomputacion de Galicia (CESGA)
Avenida de Vigo, s/n Campus Sur
15705 Santiago de Compostela - SPAIN
Tel: +34 981 56 98 10
Fax: +34 981 59 46 16
http://www.cesga.es/
