[AG-TECH] New Fedora Core 1 & 2 AGTk CVS RPMs
Jason Bell
j.bell at cqu.edu.au
Wed Jul 28 18:13:16 CDT 2004
G'day Doug
I would just like to thankyou personally for your efforts in getting the
AccessGrid software running on the latest versions of RedHat.
I found your instructions simple to follow and the software easy to
install.
Thanks and keep up and good work.
Cheers,
Jason.
Jason Bell, B.I.T.
B. Info. Tech. (Honours) Student
Network Engineer
Information Technology Division
Central Queensland University
High Performance Computing Support Officer
Research Assistant to the Nonlinear Intelligent Systems Research Group
Faculty of Informatics & Communication
E-mail : j.bell at cqu.edu.au
Phone : 07 4930 9229
Patience is a virtue.
But if I wanted Patience,
I would have become a Doctor.
-----Original Message-----
From: Douglas Kosovic [mailto:douglask at itee.uq.edu.au]
Sent: Wednesday, 28 July 2004 19:46
To: AG Technical
Subject: [AG-TECH] New Fedora Core 1 & 2 AGTk CVS RPMs
This is the first time I've released AGTk CVS snapshot (pre-2.3) RPMs
for
Fedora Core 1, they can be found at:
http://www.itee.uq.edu.au/~agn/ag_fedora/
Be sure to follow the pre-installation instructions on that page if you
have
an existing AGTk-2.1.2 or earlier installation, otherwise the yum
install
will fail when it tries to delete the old /usr/lib/globus directory
which
contains a number of files that weren't under RPM control.
I've also update the Fedora Core-2 AccessGrid RPM, as the CVS repository
contains a number of Venue Management bug fixes since the last RPM was
released.
Cheers,
Doug
