[AG-TECH] problems building VIC and RAT on AG 2.2.6 source
John Hodrien
johnh at comp.leeds.ac.uk
Mon Jul 26 05:40:10 CDT 2004
On Mon, 26 Jul 2004, Benjamin Khoo wrote:
> hi
> i am trying to build AG2.2 on Fedora Core 2
> with GT3.0.2
> i ran into many errors when compiling RAT and VIC.
> for RAT, some of the build files refer to a "ag-rat" directory which
> caused build failures of "no file found" i hacked around the ag-media
> directory and managed to get RAT compiled.
> however, now i found a similar problem with VIC. the directories being
> created doesn't seem to be what the RPM Spec file is looking for. after
> i hacked the script to get it to start compiling, i get the error below.
> is anyone able to help?
> thanks lots in advance
> ../tcl-8.0/unix/libtcl8.0.a(tclUnixPipe.o)(.text+0xb3): In function
> `TclpCreateTempFile':
> : warning: the use of `tmpnam' is dangerous, better use `mkstemp'
> codec/tmndec/libh263.a(tmndec.o)(.text+0x781): In function `getval':
> /disks/space0/turam/build/BUILD/ag-media/vic/codec/tmndec/tmndec.c:657:
> undefined reference to `__ctype_b'
> collect2: ld returned 1 exit status
Save fixing the code I think the following is quite an easy way to fix it?
http://oss.sgi.com/archives/info-inventor-dev/2004-02/msg00004.html
jh
"I happen to feel that the degree of a person's intelligence is directly
reflected by the number of conflicting attitudes she can bring to bear on the
same topic." -- Lisa Alther
