[AG-TECH] Osprey Cards....... Desperation
Stuart Poulton
stuart.poulton at astro.le.ac.uk
Fri Jul 23 03:16:54 CDT 2004
No joy again,
I still get complaints from the osprey driver that I need simulstream.
Does anyone have 4 osprey cards working under windows XP with any
version of the accessgrid software ?
Regards
Stuart
On Thu, 2004-07-22 at 13:42, A Quay wrote:
> Stuart,
> This hack from Darran worked for me and saved my life!
> -andy
> Problem:
> For nodes with multiple Osprey cards running AGTk-2.2 under Windows XP,
> multiple instances of vic contend for the same capture card. The
> workaround is to manually resolve the vic contentions after changing
> venues. This is a pain. Pending a proper fix, you might wish to try
> the following. It works for us - your mileage may vary.
> Hack:
> 1) On your video machine, open the file
> c:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py
> Save a copy of this file so you can undo the following if
> necessary.
> 2) Line 985 should be the definition of the SystemConfig class
> method GetResources:
> def GetResources(self):
> Return a list of the resources available on the system
> 3) This method builds a list of AGVideoResource entries (one
> for each capture device) by scanning your Windows registry.
> Our registry did not contain entries for both Osprey cards.
> Rather than change the registry, the following hack sets
> the list of "found" resources explicitly.
> Around line 1020, a return statement sends back the list
> of discovered resources. Insert the following code indented
> the same amount as the final return statement.
> # hack to hardcode known resources
> resourceList = list()
> resourceList.append( AGVideoResource(
> 'video', 'o100vc.dll - Osprey Capture Card 1','producer',
> ['external-in']))
> 'video', 'o100vc.dll - Osprey Capture Card 2','producer',
> ['external-in']))
> 'video', 'o100vc.dll - Osprey Capture Card 3','producer',
> ['external-in']))
> print "hack to hardcode known video resources ..."
> return resourceList
> 4) Save and restart your video machine AGServiceManager. You
> should see the "hack to hardcode .." print statement output.
> 5) "Manage my node" and remove and re-add the VideoProducer services.
> You should be prompted for the desired resource.
> 6) Let me know if it works ...
> Cheers,
> Darran.
