[AG-TECH] Node Services in CVS
Michael Miller
mimiller at ncsa.uiuc.edu
Wed Jul 21 13:27:54 CDT 2004
I've set up CVS on my winxp machine. When I run the venue client and
manage my node, I can add the service manager for localhost:11000 but
there's no services listed. I looked at my AGtk2.2 installation and there
is a "NodeServices" directory with 4 zip files for audio and video
services. I don't see these files in the same directory where I checked
out the source. And looking at the HTML CVS view on www.accessgrid.org I
don't see the directory either.
To solve the problem, I copied the zip files from my AGtk2.2/NodeServices
dir to the one in the source directory. That fixed things and I can now
get into a venue etc...
Did I miss something when I checked out CVS or is there something more that
is supposed to be done to access the node services from CVS?
The reason I ask, is that I have an idea for a node service and I wanted to
be sure I understood how the current ones work before jumping in the deep
end... ;-)
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
