[AG-TECH] My Passphrase
Mike 'Mike' Jones
mike.jones at man.ac.uk
Wed Jul 21 10:47:29 CDT 2004
Nigel,
Tom is right: your passphrase is used to encrypt /your/ private key which
you generated. If all this certificate lark is done properly, there
should only ever be one private key for your certificate (in your case,
this is almost certainly the true) and you locked your private key with a
passphrase before you sent the certificate request of to the accessgrid
CA.
If you can't remember your passphrase you have two options, crack it or
scrap it! If you can crack your passphrase you probably should have used
a better one!
The best course of action is to try all your usual passphrases and maybe
some variations that may have occured accidentally (up to 5 minutes); if
not successful, bin the certificate and request a new one. If the
Accessgrid CA is a strong CA it will require that you revoke your old
certificate.
Best of luck,
Mike
On Wed, 21 Jul 2004, Thomas Uram wrote:
> Nigel:
> There is unfortunately no way to recover the lost password. You'll have
> to request a new certificate.
> Tom
> Nigel Cooke wrote:
> > I agree and I must have either used a random one or have mis-typed
> > what I thought was correct - Any way to recover ?
> > Nigel
> > Monika Rabarison wrote:
> >>Nigel,
> >>I recall giving a passphrase or password when applying for a certificate.
> >>Monika
> >>On Wed, 21 Jul 2004, Nigel Cooke wrote:
> >>>Hi,
> >>>I finally got AG up and running on our Windows XP box and applied for a
> >>>cert - now every time I try to go into a venue its asking me for a
> >>>passphrase - I dont ever remember putting one in but any of the usual
> >>>ones I would use are not accepted ?
> >>>Any ideas ?
> >>>Nigel
> >>Monika Rabarison
> >>Systems Administrator
> >>Information Technology/HPCVI
> >>Jackson State University
> >>Office:(601)979-5933
> >>SciVis Lab:(601)979-1061
> >>JSUvisNode:(601)979-1056
> >>JSUeNode:(601)979-1081
http://www.sve.man.ac.uk/General/Staff/jonesM/
