[AG-TECH] vv2 VenueServer problems?
Thomas D. Uram
turam at mcs.anl.gov
Mon Jul 19 15:50:45 CDT 2004
John:
This is one of the problems we've been seeing on the server side, so
it's not a client issue. We're pursuing this and other server issues,
so you should see them improve in the very near term.
These improvements will also speed up your entry into the venues, though
part of that time is dependent on the complexity of your node, also.
Tom
John Hodrien wrote:
> I'm just trying to get a basic setup working and I'm having some problems.
> While connected to the default venue (vv2) I find that I'm disconnected
> regularly (once every minute or two) and even moving round rooms isn't a
> clean
> experience, with it sometimes not changing room despite going through
> all the
> motions.
> Is this the sort of problem I should be expecting using that venue or not?
> Should I be debugging this one my end? From the way I'm seeing people
> appear
> and leave venues I'm thinking it's a venue glitch, but I don't know
> enough to
> be at all sure.
> Also, how fast should it be to change rooms, with a 1.8Ghz three machine
> room
> setup?
> jh
