[AG-TECH] New Fedora Core 2 AGTk CVS snapshot
Eric Olson
eolson at mcs.anl.gov
Fri Jul 16 13:07:02 CDT 2004
Hi Fred and Doug,
I checked in a small change to VideoService.py and VideoProducerService.py
in cvs that should fix the problem causing the video port settings getting
reset to the default port all the time (Bug #1067).
Let me know if it fixes that problem for you once you're able to test
it.
Eric
On Fri, 16 Jul 2004, Fred Dech wrote:
> hi Doug.
> i applied your patch to VideoService.py.
> at first i thought that it changed the character of things; i'd been using
> videoProducerServices rather than VideoServices. but i've now double and
> triple checked.
> i believe you're right when you said:
> > Notice the "invalid value for input: (null)" stderr output from
> > /usr/bin/v4lctl. I think the corresponding V4L2 driver (the bttv driver?)
> > needs some minor mods in the source code to indicate the inputs that
> > particular model of Osprey capture card has, currently all the inputs on
> > that card don't have a name.
> before the patch and after the patch, i get the same output:
> INFO:ServiceManager:__DiscoverResources
> config: invalid value for input: (null)
> valid choices for "input": "Television", "Composite1", "S-Video", "Composite3"
> INFO:ServiceManager:Service VideoService successfully started
> INFO:ServiceManager:Setting service configuration
> INFO:ServiceManager:Assigning resource to service: /dev/video0
> INFO:Toolkit:VideoService.SetResource : /dev/video0
> INFO:ServiceManager:AGServiceManager.AddService
> INFO:ServiceManager:AddService: VideoService v 2.210000 u https://sucag1.uchicago.edu:54513/packages/VideoService.zip
> INFO:ServiceManager:resourceToAssign: /dev/video1
> INFO:ServiceManager:Searching for local service package
> INFO:ServiceManager:Found local service VideoService, v2
> INFO:ServiceManager:Running Service; options: /usr/bin/python2 ['/home/aguser/.AccessGrid/local_services/VideoService/VideoService.py', 59926]
> my new Node Service config file has:
> [service2]
> packagename = VideoService.zip
> resource = resource2
> serviceconfig = serviceconfig2
> [serviceconfig2]
> encoding = h261
> mutesources = Off
> streamname = Video
> framerate = 24
> standard = NTSC
> bandwidth = 800
> transmitonstartup = On
> quality = 75
> port = S-Video
> but the VideoSerices instantiated upon startup of VenueClient still default
> to Television for input.
> i bet this is some weird driver issue as you implied.
> using VideoService i still need to swap from Composite1 to S-Video each
> time i enter a venue. but at least i can see my video. it doesn't show up
> on the Master VIC, but the two VideService Sub VICs do display it. and
> other clients can still see me.
> i'm going to take a closer look at bttv and try and figure out why those
> error messages are being produced whenever the VenueClient starts up.
> thanks.
> --fred
