[AG-TECH] New Fedora Core 2 AGTk CVS snapshot
Douglas Kosovic
douglask at itee.uq.edu.au
Fri Jul 16 07:04:53 CDT 2004
On Fri, 2004-07-16 at 04:34, Fred Dech wrote:
> and when vic fires up, i still need to change each video capture from
> Composite1 to S-Video each time i change venues.
I ended up getting a TV Capture card with more than just a composite
input and was able to reproduce the problem and then find a possible
fix.
There's a problem with the way vic processes the vic setup script (i.e.
/tmp/VideoService_*.vic) that VideoService.py generates.
A patch for VideoService.py can found here:
http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/unstable/patches/VideoService.py.patch
The VideoService.py file is located in:
~/.AccessGrid/local_services/VideoService/
VideoProducerService.py would need a similar modification if you are
using the VideoProducerService instead.
I could incorporate the modified files into VideoService.zip and
VideoProducerService.zip of a new AccessGrid RPM if the modifications
work for other people.
Cheers,
Doug
