[AG-TECH] New Fedora Core 2 AGTk CVS snapshot
Fred Dech
fdech at uchicago.edu
Thu Jul 15 13:34:37 CDT 2004
hi Doug.
i removed a different version i had of wxPython and xawtv and
installed your rpms using yum. that went smoothly.
i rebuilt my node configuration and saved it.
i still get this parsing error from the ServiceManager:
INFO:ServiceManager:Using services dir: /home/aguser/.AccessGrid/local_services
INFO:ServiceManager:__DiscoverResources
config: invalid value for input: (null)
valid choices for "input": "Television", "Composite1", "S-Video", "Composite3"
and when vic fires up, i still need to change each video capture from
Composite1 to S-Video each time i change venues.
also, i cannot see my own video in the VIC, although it is being broadcast.
aguser 4616 4416 7 12:58 pts/11 00:00:46 ./vic -u /tmp/VideoProducerServi
ce_4416.vic -C "Video" -t 127 224.2.177.155/55524
aguser 4623 4442 9 12:58 pts/11 00:01:01 ./vic -C Access Grid Lobby -t 12
7 -XrecvOnly 1 224.2.177.155/55524
aguser 4630 4433 5 12:58 pts/11 00:00:36 ./vic -u /tmp/VideoProducerServi
ce_4433.vic -C "Video" -t 127 224.2.177.155/55524
with my previous version of AG2.2, i could launch VIC by itself
(e.g vic 224.2.177.155/55524) and see my video streams along with the others
once i'd set the port from Composite1 to S-Video. that is no longer the
case.
if i disable my firewall i don't get my video feeds in VIC.
these are almost identical to the problems i was having before.
it must be an Osprey-specific issue.
--fred
On Thu, Jul 15, 2004 at 04:32PM, Douglas Kosovic said:
> Hi,
> A new Fedora Core 2 AGTk CVS snapshot RPM can be found here:
> http://www.itee.uq.edu.au/~agn/ag_fedora/
> More info can be found on that page.
> Cheers,
> Doug
