[AG-TECH] BridgeServer and other problems....
Benedikt Bjarni Bogason
benedib at hi.is
Thu Jul 15 09:50:04 CDT 2004
> Hi,
> I was also trying to get the Bridge to work yesterday... I
> finally figured out how to make it work just now. The configuration you
> posted isn't quite right. Here is what I used, and it worked like a charm.
> [BridgeServer]
> qbexec = /usr/bin/QuickBridge
> name = some_name
> location = here
> [https://<address>:<port>/Venues/default]
> type = Venue
> This is for a single Venue, if you want for a server
> Put VenueServer as the type, and of course put the correct url.
> I had to look into the code to get this working. If you want to see for
> yourself it's in the LoadConfig function in the BridgeServer class
> Even the examples at the end of the code aren't correct; they don't use
> the
> correct capitalization.
> André Doiron
Yes, the capitalization was my fault, but the instructions on the website
are a bit misleading
http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/BridgeServer-HowTo/BridgeServer-HOWT1.htm.
But THANK YOU, it worked like a dream!
Anyone have any ideas about the rest of questions? (The vic actually now
just shuts down after asking my name and email with a runtime error!
Program: ...tion Data\AccessGrid\local_services\VideoService\vic.exe
This application has requested the Runtime to terminate it in an unusual
way. Please contact the application's support team for more information.)
Shall I just uninstall AG and reinstall it??
>>Hi everybody.
>>I have a few issues and I hope someone can answer some of them:
>>1) I'm now successfully running a VenueServer on Redhat 9 machine on an
>>intranet, and been able to connect to with an WinXP laptop. Now I am
>>trying to run a Bridgeserver (on the same machine) for the venues I
>>created.
>>This is the config file I use, ~/bridgeconfig.conf:
>> [BridgeServer]
>>name = BTexact
>>location = Adastral Park Ipswich
>>venueServer = https://accessgrid.futures.bt.co.uk:8000/VenueServer
> <https://accessgrid.futures.bt.co.uk:8000/VenueServer>
>>and I execute the command: BridgeServer.py -c ~/bridgeconfig.cnf
>>But nothing happens, it doesn't print anything to the screen, and the
>>Unicast option is not availables in any of the venues. The logfile
>> doesn't
>>give me any hints, this is it's last entry:
>>07/14/04 11:54:30 1074127616 CertificateManager
>>CertificateManager.py:876 DEBUG Proxy /tmp/x509up_u500 will expire
>>07/14/04 18:53:13
>> (I even tried to change the last line of the config file to venue
>> >https://accessgrid.futures.bt.co.uk:8000/Venues/default
> <https://accessgrid.futures.bt.co.uk:8000/Venues/default> but no such
> luck.)
>>2) Whenever my WinXP connects to a venue and the vic starts up it asks me
>>to enter rtpName and rtpEmail and then promises to store it in the
>> Windows
>>registry so I won't have to type it again, but it doesn't and I do! And
>> it
>>is a bit boring to do it every time! Is this because I am not an
>>administrator of the computer? I remember this happening when I installed
>>AG on another computer, but if I remember correctly it stopped after I
>>rebooted.
>>3) I have to start up VenueClient using a Dospromt: VenueClient
>>--personalNode. I googled this problem and someone adviced that I removed
>>the system variable GLOBUS-HOSTNAME (which I did, although difficult
>> since
>>i am not an administrator) and it certainly was wrong, but it didn't fix
>>the problem, vic and rat wouldn't start and I couldn't add a
>>ServiceManager with hostname:localhost and port:12000. It still uses the
>>wrong ip-number.
>>4) I cant open a shared browser. I can start the application session (add
>>a browser to the venue) but I can't open it on my WinXP (and certainly
>> not
>>on my linux, it only works for windows, right?). This I could do when my
>>VenueServer was running on a Windows machine.
>>This is about it for now. Hope you can help, at least on some of those
>>issues.. Thanks.
>>Benedikt.
