[AG-TECH] Fedora C2 & Ospreys
Fred Dech
fdech at uchicago.edu
Tue Jul 13 10:20:17 CDT 2004
i started to submit a Bugzilla yesterday, but stopped because the binary
version of AG2.2 i installed is not the official AG2.2. it is a Fedoraized
AG2.2 rpm set from the UK.
i have noticed that the nodeConfig file generates a parsing error
upon read-in. the serviceconfig associated with the service associated
with the video resource fails consistently to be parsed correctly
on the 'port' field (which is actually called the 'input' field in the
error message. on a hunch, i changed the fieldname to 'input' but that
did not help) upon read in.
e.g.,
[serviceconfig1]
encoding = h261
streamname = Video
framerate = 24
standard = NTSC
bandwidth = 800
quality = 75
port = S-Video
config: invalid value for input: (null)
valid choices for "input": "Television", "Composite1", "S-Video", "Composite3"
the official release AG2.2 binary pukes (and i should submit that in Bugzilla
although if i search, i'm sure someone already has)
on a FedoraC2 box at the very end when it is referencing or sourcing some
AG2 .py scripts.
so i 'may' try and build AG2.2 on that system from source.
--fred
On Tue, Jul 13, 2004 at 10:07AM, christoph ganser said:
> hi list
> Fred Dech wrote:
> > i'm going to start looking at my saved config files, etc. and the args
> >that are sent to VIC when it is started from within the Venue Client to try
> >and figure out why things aren't working.
> i have the same problem with the ports.
> the ag-config-file seems to me ok.
> the file passed to vic as a script (/tmp/xyz.vic) is also ok.
> i guess either vis does not understand the script commands or vic has a bug!
> regards
> christoph
> >--fred
> >On Mon, Jul 12, 2004 at 01:49PM, Ivan R. Judson said:
> >>This might be too elementary to have not been done, but have you tried
> >>reconfiguring using the Node Management stuff and saving your new
> >>configuration?
> >>Instructions are at:
> >>http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/VENUE_CLIEN
> >>T_MANUAL_HTML/VenueClientManualHTML.htm
> >>Look under section 2.13 Managing your node
> >>--Ivan
> >>>-----Original Message-----
> >>>From: owner-ag-tech at mcs.anl.gov
> >>>[mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of ULM AccessGrid
> >>>Sent: Monday, July 12, 2004 1:42 PM
> >>>To: 'Fred Dech'
> >>>Cc: ag-tech at mcs.anl.gov
> >>>Subject: RE: [AG-TECH] Fedora C2 & Ospreys
> >>>The port problem has been filed under bug 1067.
> >>>I have tried everything to fix the port problem. Even if I
> >>>hardcode the values it reverts back to Composite1.
> >>>Thanks
> >>>Adam
> >>>[mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Fred Dech
> >>>Sent: Monday, July 12, 2004 1:07 PM
> >>>To: ULM AccessGrid
> >>>Subject: Re: [AG-TECH] Fedora C2 & Ospreys
> >>>yeah. i believe the video port issu is a feature that should
> >>>be investigated further.
> >>>all this time i assumed i wasn't transmitting video because
> >>>my two sources don't show up on VIC. i actually decided to
> >>>test with another node to see what came up when i was
> >>>swapping out S-Video for composite, etc. it turns out that
> >>>when i've configured my VideoProducerServices to S-Video,
> >>>rather than TV (i have to do this whenever i start up the
> >>>Venue Client, but it sticks when switching venues), and i've
> >>>switched my video transmission ports from
> >>>composite1 to S-Video each time i enter a venue, then i
> >>>actually am transmitting correct (more or less) video to
> >>>other clients connected to the venue.
> >>>i just can't see my video sources at my node.
> >>>i disabled my firewall, thinking that this might be caused by
> >>>blocked loopbacks as was discussed relating to RAT last week.
> >>>but that is not the problem, apparently, since VIC still
> >>>doesn't display my streams.
> >>>'anybody else running into this?
> >>>thanks.
> >>>--fred
> >>>On Mon, Jul 12, 2004 at 10:43AM, ULM AccessGrid said:
> >>>>I have sort of the same problem. My VICs all default to
> >>>composite1.
> >>>>If I manually change the port in the vic menu to
> >>>Composite2, I see my
> >>>>video
> >>>just
> >>>>fine. As soon as I change rooms it defaults back to
> >>>Composite1. It's
> >>>like
> >>>>it ignores the node management resource settings for the ports.
> >>>>Any other linux users running 2.2 have this problem???
> >>>>Note, I do not have opprey cards. I am running pinnacle
> >>>PCTV Pro cards.
> >>>>This is because they support PCI-X slots (which my machines
> >>>have more
> >>>>of
> >>>the
> >>>>regular pci slots) But the problem sounds the same :-)
> >>>>Thanks
> >>>>Adam
> >>>Behalf
> >>>>Of Fred Dech
> >>>>Sent: Monday, July 12, 2004 10:00 AM
> >>>>To: Andrew Daviel
> >>>>Cc: AG Tech List
> >>>>On Fri, Jul 09, 2004 at 06:15PM, Andrew Daviel said:
> >>>>>On Fri, 9 Jul 2004, Fred Dech wrote:
> >>>>>>i believe that i have a configuration problem aside from AG2.2
> >>>>>>with
> >>>>these
> >>>>>>Osprey100 cards.
> >>>>>>when i run xawtv, should i be able to see the output of one of
> >>>>>>these cards? i've tried using the -device option but haven't
> >>>>>>found anything it would accept.
> >>>>>xawtv = Linux ??
> >>>>it's part of the AG2.2 install prereqs, if i remember right.
> >>>>>If so, there should be entries in the syslog and the bttv module
> >>>>>should
> >>>be
> >>>>>installed (lsmod |grep bttv) . There's install options
> >>>for bttv.o to
> >>>>>set the card type, BTW, if it's not autodetected (affects
> >>>which port
> >>>>>is
> >>>>assigned to TV, s-video
> >>>>>etc.)
> >>>>>May need "alias char-major-81 bttv" in /modules.comf
> >>>(should be set
> >>>>>by
> >>>>>kudzu) to install module automatically
> >>>>>Cards should also show up with "lspci", e.g.
> >>>>>00:0b.0 Multimedia video controller: Brooktree Corporation Bt878
> >>>>>Video Capture (rev 02)
> >>>>>Cards should show up (nowadays) in /dev/video0, video 1
> >>>etc so try
> >>>>>xawtv -c /dev/video0. I think it still defaults to
> >>>/dev/video which
> >>>>>is now a directory.
> >>>>>It should be possible to run multiple copies of xawtv one
> >>>for each card.
> >>>>>I use it a lot for testing video (and for watching TV at
> >>>home ....)
> >>>>thanks for the detailed description, Andrew.
> >>>>this system has bttv installed, and they show up in modeprobe and
> >>>>lspci shows 2 Bt878 Video Captureres.
> >>>>i'm firing up xawtv -c /dev/video0
> >>>>i'll be damned. i can see myself. and i'm having a bad hair day...
> >>>>huh.
> >>>>i must have been pointing toward the wrong device IDs in my
> >>>previous
> >>>>attempts.
> >>>>i think i did point at /dev/video1(2) at some point and got
> >>>nothing,
> >>>>but didn't bother to right-click. it defaults to PAL and TV. it
> >>>>works much better as NTSC and S-Video :-P
> >>>>xawtv -c /dev/video0 and
> >>>>xawtv -c /dev/video1 both work.
> >>>>so i guess it Is an AG config problem. i still get blue
> >>>screens in my
> >>>>two sub-VICS, and i don't show up at all in the master-VIC.
> >>>>i hacked at
> >>>>/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py
> >>>>complements of Adam Taylor....
> >>>> def GetResources(self):
> >>>> deviceList = dict()
> >>>> videodevpath = '/dev'
> >>>> v4lctlexe = '/usr/bin/v4lctl'
> >>>> if os.path.exists('/sys/class/video4linux'):
> >>>> videodevpath = '/sys/class/video4linux'
> >>>> # Get list of devices
> >>>> cmd = "ls /sys/class/video4linux | grep video"
> >>>> fh = os.popen(cmd,'r')
> >>>> for line in fh.readlines():
> >>>> device = os.path.join('/dev',line.strip())
> >>>> deviceList[device] = None
> >>>> fh.close()
> >>>>so i can get these two VideoProducerServices in my AG Node
> >>>Managment:
> >>>>VideoProducerServices /dev/video0 Enabled
> >>>>VideoProducerServices /dev/video1 Enabled
> >>>>Configuration for both:
> >>>>streamname Video
> >>>>port S-VIdeo
> >>>>encoding h261
> >>>>standard NTSC
> >>>>when i select 'Menu' on my sub-VICs, i have:
> >>>>'Device' v4I- BT878 video (Hauppauge (bt848))
> >>>/dev/video0(1) 'Signal'
> >>>>NTSC 'Port' option always defaults to Composite1 whenever i change
> >>>>venues??
> >>>>changing it to S-Video doesn't seem to help, though. still no me.
> >>>>this is getting to be very time-consuming.
> >>>>--fred
> Swiss Federal Institute of Technology - Center for Product Development
> Tannenstrasse 3 - CLA E 14.1
> 8092 Zurich - Switzerland
