[AG-TECH] Fedora C2 & Ospreys
ULM AccessGrid
accessgrid at ulm.edu
Mon Jul 12 10:43:34 CDT 2004
I have sort of the same problem. My VICs all default to composite1. If I
manually change the port in the vic menu to Composite2, I see my video just
fine. As soon as I change rooms it defaults back to Composite1. It's like
it ignores the node management resource settings for the ports.
Any other linux users running 2.2 have this problem???
Note, I do not have opprey cards. I am running pinnacle PCTV Pro cards.
This is because they support PCI-X slots (which my machines have more of the
regular pci slots) But the problem sounds the same :-)
Thanks
Adam
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Fred Dech
Sent: Monday, July 12, 2004 10:00 AM
To: Andrew Daviel
Cc: AG Tech List
Subject: Re: [AG-TECH] Fedora C2 & Ospreys
On Fri, Jul 09, 2004 at 06:15PM, Andrew Daviel said:
> On Fri, 9 Jul 2004, Fred Dech wrote:
> > i believe that i have a configuration problem aside from AG2.2 with
these
> > Osprey100 cards.
> > when i run xawtv, should i be able to see the output of one of these
> > cards? i've tried using the -device option but haven't found
> > anything it would accept.
> xawtv = Linux ??
it's part of the AG2.2 install prereqs, if i remember right.
> If so, there should be entries in the syslog and the bttv module should be
> installed (lsmod |grep bttv) . There's install options for bttv.o to set
> the card type, BTW, if it's not autodetected (affects which port is
assigned to TV, s-video
> etc.)
> May need "alias char-major-81 bttv" in /modules.comf (should be set by
> kudzu) to install module automatically
> Cards should also show up with "lspci", e.g.
> 00:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video
> Capture (rev 02)
> Cards should show up (nowadays) in /dev/video0, video 1 etc
> so try xawtv -c /dev/video0. I think it still defaults to /dev/video
> which is now a directory.
> It should be possible to run multiple copies of xawtv one for each card.
> I use it a lot for testing video (and for watching TV at home ....)
thanks for the detailed description, Andrew.
this system has bttv installed, and they show up in modeprobe and lspci
shows 2 Bt878 Video Captureres.
i'm firing up xawtv -c /dev/video0
i'll be damned. i can see myself. and i'm having a bad hair day...
huh.
i must have been pointing toward the wrong device IDs in my previous
attempts.
i think i did point at /dev/video1(2) at some point and got nothing, but
didn't bother to right-click. it defaults to PAL and TV. it works much
better
as NTSC and S-Video :-P
xawtv -c /dev/video0 and
xawtv -c /dev/video1 both work.
so i guess it Is an AG config problem. i still get blue screens in my two
sub-VICS, and i don't show up at all in the master-VIC.
i hacked at
/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py
complements of Adam Taylor....
def GetResources(self):
deviceList = dict()
videodevpath = '/dev'
v4lctlexe = '/usr/bin/v4lctl'
if os.path.exists('/sys/class/video4linux'):
videodevpath = '/sys/class/video4linux'
# Get list of devices
cmd = "ls /sys/class/video4linux | grep video"
fh = os.popen(cmd,'r')
for line in fh.readlines():
device = os.path.join('/dev',line.strip())
deviceList[device] = None
fh.close()
so i can get these two VideoProducerServices in my AG Node Managment:
VideoProducerServices /dev/video0 Enabled
VideoProducerServices /dev/video1 Enabled
Configuration for both:
streamname Video
port S-VIdeo
encoding h261
standard NTSC
when i select 'Menu' on my sub-VICs, i have:
'Device' v4I- BT878 video (Hauppauge (bt848)) /dev/video0(1)
'Signal' NTSC
'Port' option always defaults to Composite1 whenever i change venues??
changing it to S-Video doesn't seem to help, though. still no me.
this is getting to be very time-consuming.
--fred
