[AG-TECH] hack to solve Osprey problem under AGtk2.2 and WinXP ...
A Quay
andy at arts.ufl.edu
Wed Jul 7 16:54:23 CDT 2004
Darran,
Your fix worked for me. Thanks a million!
Andy
-----Original Message-----
From: Darran Edmundson [mailto:darran.edmundson at anu.edu.au]
Sent: Tuesday, July 06, 2004 1:31 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] hack to solve Osprey problem under AGtk2.2 and WinXP
Problem:
For nodes with multiple Osprey cards running AGTk-2.2 under
Windows XP, multiple instances of vic contend for the same
capture card. The workaround is to manually resolve
the vic contentions after changing venues. This is a
pain. Pending a proper fix, you might wish to try the
following. It works for us - your mileage may vary.
Hack:
1) On your video machine, open the file
c:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py
Save a copy of this file so you can undo the following if
necessary.
2) Line 985 should be the definition of the SystemConfig class
method GetResources:
def GetResources(self):
Return a list of the resources available on the system
3) This method builds a list of AGVideoResource entries (one
for each capture device) by scanning your Windows registry.
Our registry did not contain entries for both Osprey cards.
Rather than change the registry, the following hack sets
the list of "found" resources explicitly.
Around line 1020, a return statement sends back the list
of discovered resources. Insert the following code indented
the same amount as the final return statement.
# hack to hardcode known resources
resourceList = list()
resourceList.append( AGVideoResource(
'video', 'o100vc.dll - Osprey Capture Card 1','producer',
['external-in']))
'video', 'o100vc.dll - Osprey Capture Card 2','producer',
['external-in']))
'video', 'o100vc.dll - Osprey Capture Card 3','producer',
['external-in']))
print "hack to hardcode known video resources ..."
return resourceList
4) Save and restart your video machine AGServiceManager. You
should see the "hack to hardcode .." print statement output.
5) "Manage my node" and remove and re-add the VideoProducer services.
You should be prompted for the desired resource.
6) Let me know if it works ...
Cheers,
Darran.
Darran Edmundson (darran.edmundson at anu.edu.au)
ANU Supercomputer Facility Vizlab
Australian National University, Canberra, ACT 2600
tel: +61 2 6125-0517 fax: +61 2 6125-5088
