[AG-TECH] problems starting AGNodeService ...
Sabihuddin, Siraj
Siraj.Sabihuddin at nrc-cnrc.gc.ca
Tue Jul 6 08:48:57 CDT 2004
I've noticed the same problem occasionally here at NRC (both on PIG nodes
and our multi-machine node in windows). Usually this is caused by stray
python processes still running after the Venue Client has shutdown
improperly. (I'm not certain whether the service manager contributes to the
problem)
Going into the task manager and killing off these processes before restart
usually fixes the problem. Occasionally it is necessary to reboot the
machine to get the VenueClient running again.
Siraj
Student Programmer
Information Security Group, Institute for Information Technology
National Research Council (NRC), Ottawa, Canada
Email: Siraj.Sabihuddin at nrc-cnrc.gc.ca,
WWW - NRC: http://iit-iti.nrc-cnrc.gc.ca
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Darran Edmundson
> Sent: Monday, July 05, 2004 11:09 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] problems starting AGNodeService ...
> I'm having problems with AGTk2.2 in that the VenueClient
> is hanging on startup. You know, when the progress bar
> zips across to about 75% complete and then pauses
> indefinitely. (This under WinXP.)
> Trying things manually, AGServiceManager seems to start
> up fine but then I get the following with AGNodeService:
> C:\Program Files\AGTk-2.2\bin>python AGNodeService.py
> <Fault SOAP-ENV:Client: Method Not Found: ServiceManager:IsValid :
> exceptions.Ke
> yError 'ServiceManager' <traceback object at 0x01281CD8>>
> Error loading default node configuration
> Has anyone else observed this? Same problem whether
> or not ServiceManagers are running on the other two
> machines in the node.
> Cheers,
> Darran.
