[AG-TECH] Python 2.3
    Ivan R. Judson
    judson at mcs.anl.gov
    Tue Jan  6 09:32:56 CST 2004
The python 2.2 path is hardcoded in the installer, not in the actual code.
If you grab the code from cvs it'll work fine. You will have to manually
install the auxillary modules, but in the case of python 2.3 you do *not*
need the logging module (it's included in 2.3).
We're working on a python version independent installer for the next release
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Randy Heiland
> Sent: Tuesday, January 06, 2004 9:15 AM
> To: Steve Gallo
> Cc: agtk
> Subject: RE: [AG-TECH] Python 2.3
> Actually, I searched for such a hardcoded path, so that I
> might tweak it (just call me "Mr. Dangerous"), but was unable
> to find one.
> Randy
> On Tue, 2004-01-06 at 10:11, Steve Gallo wrote:
> > I had tried this during an AG 2.1.2 install but the install failed
> > because of a hard-coded path to the Python 2.2 directory so
> I backed
> > off to Python 2.2
> > Steve
> [mailto:owner-ag-tech at mcs.anl.gov]On
> > > Sent: Tuesday, January 06, 2004 9:40 AM
> > > To: agtk
> > > Subject: [AG-TECH] Python 2.3
> > > Apologies if this has been asked before - a quick search
> here turned
> > > up empty -
> http://agmailarchivers.ncsa.uiuc.edu/cgi-bin/agmailarchivers/searcha
> > > rchive.pl?type=MAIL&&archive=AGTECH&&username=ANONYMOUS
> > > but, can I install the AGTk if I've got Python 2.3
> instead of 2.2?
> > > More generally, I've recently replaced my ActiveState Python 2.2
> > > with the Enthought 2.3 version (yes, I've violated the first
> > > dependency in the AG Setup docs).  Not sure what "Win32
> extensions"
> > > might be provided in the ActiveState version that aren't
> in the Enthought version, if any.
> > > thanks,
> > > Randy
