[AG-TECH] RE: [vconf] multicast config (Nortel) ?
Born, Randy
Randy.Born at nrc-cnrc.gc.ca
Wed Feb 18 14:21:00 CST 2004
** include this line in reply to prevent spamtrapping **
Andrew
1. Did you folks ever get anywhere with your Nortel Multicast coiguration
2. Also did you find any good introductions to multicast networking
tutorials/courses/books
Randy Born
Network Manager /Gestionnaire de réseaux
(613) 993-8549 / Fax: (613) 952-7151
NRC Institute for Information Technology / Institut de technologie de
l'information du CNRC
http://iit-iti.nrc-cnrc.gc.ca
National Research Council Canada/Conseil national de recherches du Canada
M50, 1200 chemin Montreal Rd., Ottawa, ON, K1A 0R6
Government of Canada / Gouvernement du Canada
-----Original Message-----
To: ag-tech at mcs.anl.gov; vconf at canarie.ca
Sent: 2/7/03 1:41 AM
Subject: [vconf] multicast config (Nortel) ?
I'm having some trouble configuring multicast routing and wondered if anyone
had any experience with Nortel equipment (or just general advice).
We have a Nortel Passport 8600 (8603 ?) router and BayStack 450 switches.
We are connected to CA*net and hence Internet2 via BCnet. See Fig 1
(attached). We have a static RP set on the passport using an address
supplied by
BCnet.
We have 3 ports on the router grouped into a VLAN feeding our network
which is a flat class B. We have SGMP snooping enabled on the switches,
currently version 2 I think, plus multicast throttling after the SQL
Slammer fun & games. I think there is PIM sparse mode enabled on the
router; I am not sure whether IGMP snooping is turned on on the router; I
have been playing with settings trying to get it to work.
Currently, if I fire up SDR, stations A & B can see announcements from the
Internet, but C and D cannot. (D is my desktop so it's really
annoying...)
If I send simple multicast packets from A,B,C or D then the other stations
can see them (this is a tiny ping-like thing I hacked together from a CS
course assignment somewhere). If I create sessions in SDR on one of the
stations then the others can see them, usually. D will see C immediately, A
will see B immediately, and there may be a delay for A to see C or D.
We recently tried a test to a site on CA*net from B using static
ip addresses e.g. "vic 224.4.5.6/1234". We could see them but they could
not see us. It occurred to me later that I may not have started vic with a
big enough TTL; I think I had set the threshold in the Passport to 15.
Years ago we had the Mbone working with mrouted and a tunnel - only two
parameters, an address and a threshold. Now it is much more complex with
PIM, IGMP, DVMRP etc. so I am getting a bit confused.
Ideally I would like multicast to work anywhere on site, and we would like
to restrict the multicast data e.g. AG video from going down branches
where it is not required, which I think is what IGMP snooping will do for
us. So I'd like to understand what it is about port 4 and port 6 that
means one works and one doesn't (I can't see any config differences). And of
course I would like to be able to send offsite.
Suggestions ?
Anyone know a good introduction to multicast networking, preferably
free & online - though a good book would work too ?
Andrew Daviel, TRIUMF, Canada
Tel. +1 (604) 222-7376
security at triumf.ca
<<Fig. 1>>
