[AG-TECH] multicast problem
Dioselin Gonzalez
dioselin at purdue.edu
Fri Feb 13 09:17:26 CST 2004
Hi, this is for the network gurus :-) :
The administrators told me the network is already multicast
enabled. I checked on a third workstation and multicast works fine.
But the other two computers still have the problem (not multicast enabled).
Why would some computers be multicast and others not?
I know this is a general network issue and not AG specific, but if you
can point me out to some resources I would appreciate it
Thanks!
Dio.-
Charles R. Anderson wrote:
>On Thu, Feb 12, 2004 at 09:43:19AM -0500, Dioselin Gonzalez wrote:
>>I installed AGTk 2.1.2 on a couple of workstations at the lab. I cannot
>>see any video, and Internet2 detective says multicast is not enabled.
>>However, when I connect my laptop in the lab, it says multicast is
>>enabled and I can see video.
>Multicast pretty much always works when confined to a single LAN
>subnet, which is the case when you connect your laptop in the lab.
>>Is there anything I should configure on the workstations to use multicast?
>No, your network administrator needs to configure multicast to work
>across subnets and out to Internet2.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040213/1cbff59f/attachment.htm>
