[AG-TECH] hauppauge video problems
Bob Riddle
bdr at internet2.edu
Thu Feb 12 11:44:54 CST 2004
yes - but as Mike said, every time I switch venues and vic(s) restart, I
get the little window (for each instance of vic) that asks me to choose
my video source. That doesn't annoy me, so I'm a happy Spectra8 card
user (and I opened up a couple more PCI slots!)
Osland, CD (Chris) wrote:
>Just to check, Bob...
>You say you're using the Spectra8 card - do I assume that you're
>using it successfully!? Under XP? If so, that's the way I'm
>going to go as well.
>Cheers
>Chris
>____________________________________________________________________
>Chris Osland Office tel: +44
>(0) 1235 446565
>Digital Media and Access Grid Medialab tel: +44 (0)
>1235 446459
>BIT Department Access Grid room tel: +44
>(0) 1235 445666
>e-mail: C.D.Osland at rl.ac.uk Fax: +44
>(0) 1235 445597
>CLRC Rutherford Appleton Laboratory (Bldg. R18)
>Chilton, DIDCOT, Oxon OX11 0QX, UK
>[The contents of this email are confidential and are for the use of the
>intended recipient only.
>If you are not the intended recipient do not take any action on it or show
>it to anyone else,
>but return this email to the sender and delete your copy of it.]
>>-----Original Message-----
>>From: Bob Riddle [mailto:bdr at internet2.edu]
>>Sent: 11 February 2004 16:19
>>To: Michael Miller
>>Cc: Ti Leggett; Harold Micheal Goldman; AG Tech
>>Subject: Re: [AG-TECH] hauppauge video problems
>>I actually use a Spectra8 card on our "loaner" AG - it has four video
>>ports on it and works the way Michael describes. I've been
>>trying to do
>>the same thing with a 4-port Winnov card as well ... (you know, there
>>are only so many PCI port in a one-box node!)
>>Michael Miller wrote:
>>>Just to add to what Ti said:
>>>My experience has been that, depending on the driver, you
>>can select
>>>the WDM device in the configuration of multiple
>>VideoProducers. When
>>>vic starts up, one of the WDM cameras is automatically selected for
>>>the first VideoProducer. Then you are given a series of dialogs to
>>>choose a camera for each remaining VideoProducer. Again,
>>whether you
>>>get to choose another camera will depend on how the driver
>>enumerates
>>>the cameras. The QuickCam Pro 4000 does show you multiple cameras,
>>>but it gives them all the same name. So, it can be confusing when
>>>trying to choose a camera for the subsequent
>>VideoProducers. If you
>>>have two different cameras, the WDM drivers will assign names as
>>>appropriate and it's much easier to decide which camera to
>>choose. I
>>>have an iBot firewire camera and a QuickCam Pro 4000 so I can see
>>>which camera has become the default after the last session. If you
>>>have two of the same camera and the driver doesn't assign each a
>>>unique name, that's when you run into trouble.
>>>HTH
>>>Michael Miller
>>>NCSA
>>>At 05:36 PM 2/10/2004, Ti Leggett wrote:
>>>>Actually the problem is this. Vic can only handle Video
>>for Windows (VfW
>>>>devices) which is an old driver style. vic can map the
>>newer WDM drivers
>>>>to a VfW device, but it can only do that for one device.
>>Basically, if
>>>>you have drivers that are VfW then all of them will be
>>seen and usable
>>>>in vic. If the drivers are WDM only, then vic will pick a
>>device and map
>>>>and that's it. Hauppage has stopped providing VfW drivers for their
>>>>cards. Osprey, however, still provides VfW drivers for their cards.
>>>>This driver issue is also why you can only have one web
>>cam hooked up
>>>>since, I'd say, all web cams provide only WDM drivers.
>>>>Make more sense?
>>>>On Wed, 2004-02-11 at 08:35, Bob Riddle wrote:
>>>>>for what it's worth - I've been down this road and gave
>>up - while
>>>>this
>>>>>is no problem on Linux, the driver for WinXP assumes
>>that only one
>>>>WinTV
>>>>>card will be on the system. It cost less for a couple
>>of Osprey100
>>>>>cards than it did for the time I spent on trying to make
>>this work.
>>>>>sigh.
>>>>>Harold Micheal Goldman wrote:
>>>>>> Does anyone know of any way to get two hauppauge WinTv video
>>>>capture cards to
>>>>>>work at the same time in Windows XP. I am creating an
>>Access Grid
>>>>Node here at
>>>>>>the University of Southern Mississippi for Collaboration for
>>>>Genomic Research.
>>>>>>I will also be setting up similar agn's at four othe
>>universities
>>>>here in the
>>>>>>state. I had bought the two cards on the advice of a
>>friend that
>>>>admins a agn
>>>>>>for the computer science dept here at usm, but we
>>cannot get both
>>>>cards to work
>>>>>>under xp.
>>>>>>Thank You
>>>>>>Mike Goldman
>>>>>>Bioinformatics Coordinator
>>>>>>MFGN USM
>>>Thanx,
>>>Michael Miller
>>>System Engineer
>>>Visualization Technology Support
>>>Computing and Data Management
>>>National Center for Supercomputing Applications
>>>University of Illinois - UC
>>>217-649-0747
>>>"If you're clear in your vision and trust the people in
>>your team with
>>>clear objectives, they will invariably do their best to achieve
>>>everything desired, and usually deliver everything you could have
>>>hoped for and even more." -Paul Debevec
>>Bob Riddle (bdr at internet2.edu) Technologist,Internet2
>>3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
>>Business Phone: 734.913.4257 Fax Number: 734.913.4255
>>"Opportunity is missed by most people because it is dressed
>>in overalls and looks like work" Thomas Edison
"Opportunity is missed by most people because it is dressed in overalls and looks like work" Thomas Edison
