[AG-TECH] Multiple video capture in one card
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Wed Feb 11 10:25:51 CST 2004
I'm trying to set up a single processor full AG node and so am
looking at capturing more than one video stream in a card (or I
run out of PCI slots).
The iTuner Spectra-4 (and -8) can do the hardware bit,
http://www.ituner.com/spectra.htm
but they produce 4 (or 8) WDM streams. Anyone know whether I can
convert those to VfW streams by any means and thus get all my
video in with via a single card? I'm hoping to do the same for
audio, using something like the M-Audio Quattro USB, using 0 slots
(as it's a USB device, but is full duplex which is a start!).
If not via those cards, anyone know of any 2-input cards that
produce VfW streams?
Any thoughts much appreciated. Processors will be twin 2.8 GHz
Xeon, so hopefully enough oomph to drive everything; Windows XP
will be the OS for support reasons.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: Bob Riddle [mailto:bdr at internet2.edu]
> Sent: 11 February 2004 16:12
> To: Don Lewis
> Cc: Harold Micheal Goldman; ag-tech
> Subject: Re: [AG-TECH] hauppauge video problems
> actually - that's what I run on "my" laptop - but I've been
> setting up
> one-machine nodes where the node operator is an
> administrative support
> person - they seem at ease with the Windows box.
> Is anyone running a one-box OS X node?
> Don Lewis wrote:
> >Or toss XP, and use a free linux...
> >Don Lewis
> >>===== Original Message From Bob Riddle <bdr at internet2.edu> =====
> >>for what it's worth - I've been down this road and gave up
> - while this
> >>is no problem on Linux, the driver for WinXP assumes that
> only one WinTV
> >>card will be on the system. It cost less for a couple of Osprey100
> >>cards than it did for the time I spent on trying to make this work.
> >>sigh.
> >>Harold Micheal Goldman wrote:
> >>> Does anyone know of any way to get two hauppauge WinTv
> video capture cards
> >to
> >>>work at the same time in Windows XP. I am creating an
> Access Grid Node here
> >at
> >>>the University of Southern Mississippi for Collaboration
> for Genomic
> >Research.
> >>>I will also be setting up similar agn's at four othe
> universities here in
> >the
> >>>state. I had bought the two cards on the advice of a
> friend that admins a
> >agn
> >>>for the computer science dept here at usm, but we cannot
> get both cards to
> >work
> >>>under xp.
> >>>Thank You
> >>>Mike Goldman
> >>>Bioinformatics Coordinator
> >>>MFGN USM
> >>Bob Riddle (bdr at internet2.edu) Technologist,Internet2
> >>3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
> >>Business Phone: 734.913.4257 Fax Number: 734.913.4255
> >>"Opportunity is missed by most people because it is dressed
> in overalls and
> >looks like work" Thomas Edison
> >Don Lewis
> >Senior Computer Specialist
> >Graduate Institute of Technology
> >ETAS 335A, 2801 South University Avenue
> >University of Arkansas at Little Rock 72204
> >(501) 569-8016 fax: (501) 569-8039
> >djlewis at ualr.edu
> in overalls and looks like work" Thomas Edison
