[AG-TECH] NodeManagement no go
Russ Wolf
rwolf at tonka.bu.edu
Tue Feb 10 15:28:55 CST 2004
This is wierd,
the node worked last time we tried.
Today the AGServiceManagers start up fine, AGNodeService starts up fine.
When I run NodeManagement It can not load a cnofiguration
agvideo-b17:~ % NodeManagement.py
Traceback (most recent call last):
File "/usr/lib/python2.2/site-packages/AccessGrid/NodeManagementUIClasses.py",
line 558, in LoadConfiguration
configs = self.nodeServiceHandle.GetProxy().GetConfigurations()
File "/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.p
y", line 3660, in __call__
return self.__r_call(*args, **kw)
y", line 3680, in __r_call
self.__hd, self.__ma)
y", line 3580, in __call
config = self.config)
y", line 3464, in call
r.endheaders()
File "/usr/lib/python2.2/httplib.py", line 695, in endheaders
self._send_output()
File "/usr/lib/python2.2/httplib.py", line 581, in _send_output
self.send(msg)
File "/usr/lib/python2.2/httplib.py", line 548, in send
self.connect()
File "/usr/lib/python2.2/httplib.py", line 516, in connect
socket.SOCK_STREAM):
socket.gaierror: (-5, 'No address associated with hostname')
