[AG-TECH] Python error on AG installation
Douglas Baggett
dbaggett at nsf.gov
Fri Feb 6 07:16:21 CST 2004
The problem seemed to have to do with the fact that I had the IPV6 stack
installed under WinXP. As soon as I uninstalled it the client didn't
have a problem enumerating my adapter and reverse resolving my
workstation's address. I wonder if this is a bug in the python module
that was used in the script? It looks like the problem is in
winnet.enumerate_interfaces() within the globus python script.
network query raised exception
Traceback (most recent call last):
File "\PROGRA~1\ACCESS~2\bin\globus_init.pyw", line 802, in
ThreadQueryFunc
self.interfaces = winnet.enumerate_interfaces()
-Doug B
CISE/NSF
Frank Sweetser wrote:
>On Thu, Feb 05, 2004 at 03:35:08PM -0500, Douglas Baggett wrote:
>>> File "C:\Python22\Lib\site-packages\DNS\Base.py", line 137, in conn
>>> self.s.connect((self.ns,self.port))
>>> File "<string>", line 1, in connect
>>>gaierror: (7, 'getaddrinfo failed')
>>It seems like it's having problems doing a reverse lookup on my
>>hostname, but I'm able to reverse resolve my address using nslookup
>>without any problems. Is this a bug or is it something I should be
>>concerned with?
>Are you sure that nslookup is using DNS? I've caught windows nslookup
>silently falling back to WINS resolution when DNS doesn't have an
>answer.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040206/37e4fd12/attachment.htm>
