[AG-TECH] AG Certificate problems
David Cortijo
dcortijo at bnl.gov
Thu Dec 9 03:50:08 CST 2004
I checked on that. Each operator for the node has a separate login
to the machines, and as a result, doesn't have access to the
certificates of the other operators. It's not a pressing issue for me -
my certificate isn't going to see heavy use apart from testing (I
administer the machines rather than operate them for meetings), but I'm
curious as to why this is an issue.
I plan on migrating the entire system over when I have a few days
to reconfigure hardware (going to do a test run with the Debian
installation and the 2.3 Toolkit), but having access to the Windows side
as a comparison was one of those things I was relying on. If I just
apply for another certificate, that might fix things, but I don't know.
Natalia Costas Lago wrote:
> just as something to try,.... maybe u have loaded more than ur
> personal ID (the certificate of other node operator is loaded as
> well).. and the other certificate is being used as the default one?
> ----- Original Message ----- From: "David Cortijo" <dcortijo at bnl.gov>
> To: <ag-tech at mcs.anl.gov>
> Sent: Wednesday, December 08, 2004 4:00 PM
> Subject: [AG-TECH] AG Certificate problems
>> I tried to log in with a new certificate today and received the
>> message below. We're currently using AGToolkit 2.1.2 on mixed
>> Windows (2000 and XP) machines. My passphrase is correct - in fact,
>> any time I put in an invalid pass, it spits out a more generic
>> message (forgot to copy it and now I'm on another machine). Any
>> ideas what might be causing this? And before anyone suggests it, I
>> know the node's Toolkit needs to be upgraded. We simply haven't had
>> the time.
>> David Cortijo
>> Brookhaven National Laboratory
>> Error Message:
>> Creating globus proxy for /O=Access
>> Grid/OU=agdev-ca.mcs.anl.gov/OU=bnl.gov/CN=David Cortijo
>> Passphrase:
>> Lifetime in hours [12]:
>> Keysize [1024]:
>> Your identity: /O=Access
>> user_key loaded
>> user_proxy cert_chain
>> verify failed
>> Error:
>> error:80066421:lib(128):verify_callback:cannot find CA certificate
>> for local
>> credential:\software\AccessGrid\WinGlobus\source\gsi\ssl_utils\library\sslutils.c:2140
>> Got error verify_callback-->
>> error:80066412:lib(128):verify_callback:certificate::\software\AccessGrid\WinGlobus\source\gsi\ssl_utils\library\sslutils.c:2706
>> subject=/O=Access
>> issuer =/O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
>> Developers CA
>> Invalid passphrase.
