[AG-TECH] OSX Node Services
Risto Treksler
risto at elkhornbanff.ca
Mon Dec 6 16:40:55 CST 2004
Hi all,
The AudioService is a sort of a proof of concept using the VRVS rat
It works although it does not honour the Service Settings
eg. talk on by default
OTOH, The VPConsumerService should work as expected
http://irstudio.ucalgary.ca/download/OSX/AudioService.zip
http://irstudio.ucalgary.ca/download/OSX/VPConsumerService.zip
to install, place these in:
/Applications/AccessGridToolkit.app/Contents/Resources/NodeServices/
**Note**:
There's a small bug in AG where
NodeServices with more than one directory level in the zipfile
don't extract properly
Here's a patch that should go into AG,
if it hasn't already been fixed in CVS
http://irstudio.ucalgary.ca/download/OSX/Types.patch
To make current installations work, just patch the file:
/Applications/AccessGridToolkit.app/Contents/Resources/lib/python2.3/site-packages/AccessGrid/Types.py
or manually replace these lines:
# create subdir if needed
pathparts = string.split(filename, '/')
if len(pathparts) == 2:
temp_dir = os.path.join(path, pathparts[0])
if not os.access(temp_dir, os.F_OK):
os.mkdir(temp_dir)
destfilename = os.path.join(path,filename)
# Extract the file
filecontent = zf.read( filename )
f = open( destfilename, "wb" )
f.write( filecontent )
f.close()
with these lines:
if filename.endswith('/'):
if not os.access(destfilename, os.F_OK):
os.mkdir(destfilename)
else:
# Extract the file
f.close()
