[AG-TECH] Mac OS NodeServices (video/audio)
    Brian Corrie
    bcorrie at sfu.ca
    Sat Dec  4 14:24:15 CST 2004
Hello all,
Given the recent ability of VRVS based audio and video tools to work
under Mac OS we have been playing with a Mac AudioService to try and get
it to work. The VenueClient hangs when trying to add a AudioService Node
Service to a node through the node management interface.
Oddly enough, we have been playing around with VP as well, and see
exactly the same behaviour. The VenueClient hangs when trying to add a
VPVideoConsumer service. This leads me to believe that this is a generic
"Add node service to a node problem" on Mac OS, NOT an AudioService problem.
So my question is, has anyone been able to add ANY kind of a NodeService
to a node under MacOS? Markus, have you had any luck with getting a VP
node service running? Any insights into this problem? Tom, Ivan, any
comments???
Excerpt from the node service log below... Note that it seems to hang
when it try to start the service and never comes back. At this point one
has to kill the VenueClient.
Cheers,
Brian
12/03/04 15:31:49 -1610571284 ProxyGen     ProxyGen.py:551 DEBUG Using
GT24 proxy code
12/03/04 15:31:49 -1610571284 Toolkit     Toolkit.py:90 DEBUG
Initializing AG Toolkit version 2.3
12/03/04 15:31:49 -1610571284 Toolkit     Toolkit.py:132 INFO  Logfile
12/03/04 15:31:50 -1610571284 Toolkit     Toolkit.py:606 INFO  Service
init: have profile None
12/03/04 15:31:50 -1610571284 CertificateManager
CertificateManager.py:257 DEBUG Opened repository
/home/bcorrie/.AccessGrid/Config/certRepo
12/03/04 15:31:50 -1610571284 Toolkit     Toolkit.py:635 INFO
Initialized cert mgmt.
12/03/04 15:31:50 -1610571284 Toolkit     Toolkit.py:650 INFO  Loaded
profile and configured with it.
CertificateManager.py:734 DEBUG Configuring standard environment
CertificateManager.py:802 DEBUG Using default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=sfu.ca/CN=Brian Corrie
CertificateManager.py:873 DEBUG Initializing environment with proxy cert
for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=sfu.ca/CN=Brian Corrie
CertificateManager.py:907 DEBUG Looking for identity (unused) None
CertificateManager.py:892 DEBUG Configuring for user proxy issued from
CertificateManager.py:895 DEBUG Proxy /tmp/x509up_u46917 will expire
12/03/04 17:28:09
CertificateManager.py:1479 DEBUG done, success=1
12/03/04 15:31:50 -1610571284 Toolkit     Toolkit.py:654 INFO
Initialized Globus.
12/03/04 15:31:50 -1610571284 Toolkit     Toolkit.py:662 INFO  Service
Initialization Complete.
12/03/04 15:31:50 -1610571284 Toolkit     AGService.py:368 INFO
Starting Service URI: https://irmacs001.irmacs.sfu.ca:65020/Service
