[AG-TECH] [Patch] Big Linux fixup patch
Andrew Replogle
andrew.replogle at gmail.com
Wed Dec 1 17:24:19 CST 2004
Steve,
do you use gentoo at all? I was wondering if you or anyone else knew
how I might merge these changes into an "ebuild".
It seems that from the bombed out vic install theres still a dir in
/var/tmp/portage called vic with an ag-media directory in there..
would I patch there? or try to patch from the PORTDIR_OVERLAY where
the original ebuilds are?
Does anyone know who maintains the AG gentoo packages/ebuilds? Maybe
we could get them to merge this in officially?
from the /var/tmp/portage/vic-1.1.13/work I tried to run a patch -p1 <
~andrew/ag2.3-alsa-mbus-rtp-ssl.diff --dry-run
and right off I get:
The next patch would delete the file common/confdefs.h,
which does not exist!
among other things.. am I passing the correct paramter p level to
patch or is this the wrong directory.. I went to look for a confdefs.h
under common in the ag-media under this path and found none..
Any info is greatly appreciated.
Andrew
Andrew
On Mon, 29 Nov 2004 13:55:09 +1100, Steve Smith
<ssmith at vislab.usyd.edu.au> wrote:
> > I'm currently experimenting with maintaining my changes in Darcs*, which
> > would make experimental branches a lot simpler, and allow developers to
> > cherry-pick useful patches.
> I've now created a Darcs repository, you can pull it with:
> darcs get http://people.vislab.usyd.edu.au/~ssmith/accessgrid/ag-media
> This has a finer-grained set of patches that are annotated, so that may
> be more useful for integrating.
> Cheers,
> Steve
> Steve Smith, SysAdmin/Programmer | "When you have no nails your hammer grows
> Vislab, University of Sydney | restless, and you begin to throw sideways
> Phone: (02) 9351 5967 | glances at screws and pieces of string."
> Email: ssmith at vislab.usyd.edu.au | -- Jarkko Hietaniemi
