[AG-TECH] ag 2.3 gentoo amd64 vic fails to build
    Andrew Replogle
    andrew.replogle at gmail.com
    Wed Dec  1 08:28:52 CST 2004
Just the Gentoo install handbook.
http://www.gentoo.org/doc/en/handbook/index.xml
It's different from most linux installs (minus lfs maybe) in that
there really is no installer at this time. You boot from a livecd,
(2004.3 is the latest I believe ) load the modules needed for network
support and partition your drives with fdisk.. Then you chroot your
new environment and start untaring install tarballs from there.
If you're unfamiliar with this method, the install guide does a fairly
good job of guiding you through step by step. Of course I'd be happy
to answer any questions you may have as well.
Andrew
On Wed, 1 Dec 2004 05:20:36 -0600, Todd Reed <treed at astate.edu> wrote:
> Andrew,
>         I'm not sure about your current problem, but I am interested in
> building up a Video server running Gentoo.  Are you using any particular
> guide to build Gentoo?
> --Todd
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Andrew Replogle
> Sent: Wednesday, December 01, 2004 12:12 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] ag 2.3 gentoo amd64 vic fails to build
> Hello,
> I'm running gentoo on pure amd64 and grabbed the agtk bundle
> http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3
> /gentoo/AccessGrid-2.3.tar.gz
> and extracted it into /usr/local/portage which is set to my
> PORTDIR_OVERLAY in the /etc/make.conf
> when I do an emerge -aq ag-libs/agtk  everything goes fine until it hits
> vic:
> --snip--
> In file included from net_udp.c:47:
> inet_ntop.h:6: error: conflicting types for 'inet_ntop'
> /usr/include/arpa/inet.h:67: error: previous declaration of 'inet_ntop'
> was here
> was here
> make[1]: *** [net_udp.o] Error 1
> make[1]: *** Waiting for unfinished jobs....
> make[1]: Leaving directory
> `/var/tmp/portage/vic-1.1.13/work/ag-media/common/src'
> make: *** [all-recursive] Error 1
> --snip--
> Anyone run into this before?
> Any ideas are greatly appreciated.
> Andrew Replogle
