[AG-TECH] Fedora Core 2 and AG 2.3
Todd Zimmerman
toddz at sfu.ca
Tue Aug 31 16:14:08 CDT 2004
You may want to try temporarily disabling your firewall also to see if
that is the problem.
My firewall currently accepts:
established / related connections
TCP port 22 (don't think you specifically need this for AG)
udp port 47000 (rat gui)
udp ports > 50000 (RTP streams)
Plus, I'm only on unicast - so if you use multicast you'll need to
specificy that traffic also.
Todd
Jeremy Mann wrote:
> I am having no luck at ALL whatsoever with 2.3 and Fedora Core 2. When
> going to a venue, the client just hangs. I've even tried to start it from
> command line thinking I'd get an error message, but I don't. Has anybody
> seen this with Fedora Core 2?
