[AG-TECH] AGTk 2.3 BETA 2 for Fedora Released
Douglas Kosovic
douglask at itee.uq.edu.au
Sun Aug 29 23:31:19 CDT 2004
The Access Grid Toolkit 2.3 BETA 2 for Fedora is now available from:
http://www.itee.uq.edu.au/~agn/ag_fedora/
Experimental support for Shared Presentations using OpenOffice is now mostly
working, requires the openoffice.org-pyuno RPM to be installed.
The AccessGrid, globus-accessgrid and gpt RPMs have all been updated. For
FC2, the xawtv RPMs have been deleted as xawtv's v4lctl is no longer
required.
If you are using an anonymous certificate as your default identity
certificate and Node Management configuration actives don't work for you,
try setting the default to a non-anonymous identity certificate.
Doug
