[AG-TECH] CVS AGTk client cannot connect to default server (RH9.0)
    Socrates Varakliotis
    S.Varakliotis at cs.ucl.ac.uk
    Thu Aug 19 12:15:39 CDT 2004
Right, David, this is something I was wondering about:
How do we know which version of AG matches which globus?
I've downloaded the pre-WS data management client bundle:
globus-data-management-client-3.2.1-src_bundle.tar.gz
http://www-unix.globus.org/toolkit/downloads/3.2.1/#pre-ws-bundles
This is what I read in:
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/cvs-instructions.html
The paragraph on Linux says:
1. Have Globus 2.4.3 installed, instructions for that are elsewhere.
(you only *need* the globus-data-management-client bundle)
Where exactly are the instructions you mention? And where is globus 2.4.3?
AFAIK, the latest stable globus release is 3.2.1.
Any help, please?
Best Regards,
Socrates
----- Original Message -----
To: "Thomas D. Uram" <turam at mcs.anl.gov>
Cc: "Socrates Varakliotis" <S.Varakliotis at cs.ucl.ac.uk>; "ag-tech"
<ag-tech at mcs.anl.gov>
Sent: Thursday, August 19, 2004 11:06 AM
Subject: Re: [AG-TECH] CVS AGTk client cannot connect to default server
(RH9.0)
> so what versions of the globus toolkit do the various versions of AG
> require? and is this stated somewhere??
> cheers,
> David.
> On Wed, 18 Aug 2004, Thomas D. Uram wrote:
> > The 'xio' here indicates that post-2.4.3 globus was used.  AG 2.x relies
> > on globus 2.4.3, so if you install that and build pyGlobus against it,
> > this problem will be resolved.
> > Tom
> >  > GSITCPSocketException: globus_xio_gsi: gss_init_sec_context failed.
> > Socrates Varakliotis wrote:
> > > Dear All:
> > > I installed the cvs version of the AGTk on RH9.0.
> > > I also requested and was issued with a valid certificate, which I
> > > imported successfully. After launching the Venu Client with:
> > > prompt> python2.3 AccessGrid/bin/VenueClient.py --debug
> > > I cannot connect to the default venue at ANL. The output on the screen
> > > follows. The client's log file is also attached.
> > > Any help appreciated.
> > > Best Regards,
> > > 18/08/04 16:14:11 1074896032 Platform     Config.py:341 DEBUG
retrieved local IP address 128.16.66.76
> > > 18/08/04 16:14:11 1074896032 CertificateManager
CertificateManager.py:263 DEBUG Opened repository
/root/.AccessGrid/Config/certRepo
CertificateManager.py:729 DEBUG Configuring standard environment
CertificateManager.py:797 DEBUG Using default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
CertificateManager.py:868 DEBUG Initializing environment with proxy cert for
/O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates
Varakliotis2
CertificateManager.py:887 DEBUG Configuring for user proxy issued from
Varakliotis2
CertificateManager.py:890 DEBUG Proxy /tmp/x509up_u0 will expire 18/08/04
20:27:23
> > > 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:293 DEBUG
__StartWebService: venueclient: https://128.16.66.76:64182/VenueClient
> > > 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:191 DEBUG
__createPersonalDataStore: Creating personal datastore at
/root/.AccessGrid/Config/personalDataStore using prefix personalDataStore
and port 0
> > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1512 DEBUG
Creating thread 0
> > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1517 DEBUG
Starting thread 0
> > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1519 DEBUG
Waiting thread 0
> > > 18/08/04 16:14:11 1142135600 DataStore     DataStore.py:1525 DEBUG
Worker 0 starting
> > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1522 DEBUG
Done creating workers
> > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:270 DEBUG
Reading persisted data from:
/root/.AccessGrid/Config/personalDataStore/DataStore.dat
> > > 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:216 DEBUG
__createPersonalDataStore: Load personal data from file
> > > 18/08/04 16:14:11 1074896032 VenueClientController
VenueClientController.py:1343 DEBUG There is no personal venues file to
load.
> > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:802 DEBUG
EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> > > 18/08/04 16:14:18 1074896032 CertificateManager
CertificateManager.py:633 DEBUG HaveValidProxy: found proxy ident /O=Access
Varakliotis2/CN=proxy
> > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:825 INFO
EnterVenue: Error getting node capabilities
> > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:700 DEBUG
EnterVenue: Invoke venue enter
> > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:667 ERROR
SOAP fault occurred
> > > Traceback (most recent call last):
> > >   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line
347, in __call
> > >     config = self.config)
187, in call
> > >     r.endheaders()
> > >   File "/usr/local/lib/python2.3/httplib.py", line 712, in endheaders
> > >     self._send_output()
> > >   File "/usr/local/lib/python2.3/httplib.py", line 597, in
_send_output
> > >     self.send(msg)
> > >   File "/usr/local/lib/python2.3/httplib.py", line 564, in send
> > >     self.connect()
> > >   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line
1425, in connect
> > >     self.sock.connect(self.host, self.port, self.io_attr)
988, in connect
> > >     raise ex
> > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:846 ERROR
EnterVenue: globus tcp exception: ('globus_xio_gsi: gss_init_sec_context
failed.',)
> > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:853 ERROR
EnterVenue: failed
> > >   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/VenueClient.py",
line 829, in EnterVenue
> > >     self.__EnterVenue(URL)
line 701, in __EnterVenue
> > >     (venueState, self.privateId, self.streamDescList ) =
self.__venueProxy.Enter( self.profile )
> > >   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/Venue.py", line
3339, in Enter
> > >     (r1, r2, r3) = self.proxy.Enter(profile)
453, in __call__
> > >     return self.__r_call(*args, **kw)
475, in __r_call
> > >     self.__hd, self.__ma)
347, in __call
187, in call
> > >     r.endheaders()
> > >     self._send_output()
_send_output
> > >     self.send(msg)
> > >     self.connect()
1425, in connect
988, in connect
> > >     raise ex
> > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2054
DEBUG bin.VenueClient::EnterVenue: Enter venue with url:
> > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2067
DEBUG warningString:
> > > 18/08/04 16:14:28 1074896032 VenueClient     VenueClientUI.py:1701
INFO  --------- END VenueClient
> > > 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1530 DEBUG
Worker 0 gets cmd quit
> > > 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1543 DEBUG
Worker 0 exiting
> > > 18/08/04 16:14:28 1150528304 DataStore     DataStore.py:1603 ERROR
Exception handling request
> > >   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/DataStore.py",
line 1599, in thread_run
> > >     self.handle_request()
> > >   File "/usr/local/lib/python2.3/SocketServer.py", line 217, in
handle_request
> > >     request, client_address = self.get_request()
843, in get_request
> > >     raise(str(self.socket) + str(" is having trouble listening!:" +
str(ex.args)))
> > > <pyGlobus.io.GSITCPSocket instance at 0x41de94ec> is having trouble
listening!:('an I/O operation was cancelled',)
> > > 18/08/04 16:14:28 1133742896 Hosting     Server.py:65 ERROR Exception
in SOAP server main loop
> > >   File
"/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/hosting/SOAPpy/Server.py",
line 63, in Run
> > >     self._server.handle_request()
handle_request
> > >   File "/usr/local/lib/python2.3/site-packages/SOAPpy/GSIServer.py",
line 140, in get_request
> > >     sock, addr = ThreadingGSITCPSocketServer.get_request(self)
843, in get_request
str(ex.args)))
> > > <pyGlobus.io.GSITCPSocket instance at 0x41de908c> is having trouble
