[AG-TECH] Which version should I use?
    David G Mills
    dgm at ecs.soton.ac.uk
    Mon Aug 16 05:55:13 CDT 2004
Is the any guidance on installing from cvs on FC2?
David.
On Tue, 10 Aug 2004, Natalia Costas Lago wrote:
> Hi Doug,
> Maybe you mean the final??
> .. is the AGTK 2.3 rpm file located under
> :http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/RPMS for Fedora Core
> 2??. I am confused as I thought that 2.3 beta release hadnt been migrated
> yet. I followed the ag document to install AGTK 2.2
> (http://www.accessgrid.org/agdp/howto/fedora2install/1.0/book1.html), that
> was released yesterday, but there are no instructions for AGTK 2.3, only for
> AGTK 2.2. So, my question is:
> - Where can I download AGTK 2.3 beta for FC2? Is that URL indicated below?
> and
> - Should I follow the same procedure to install it as I did with AGTK 2.2?
> Should i use the same version for wxpython (in the documentation the author
> indicated some problems compiling wxpython 2.5)?
> Natalia.
> From: "Douglas Kosovic" <douglask at itee.uq.edu.au>
> To: <ag-tech at mcs.anl.gov>
> Sent: Tuesday, August 10, 2004 2:01 PM
> Subject: Re: [AG-TECH] Which version should I use?
> > Hi Natalia,
> > > Thank you very much for your answer, i was wondering when will be AGTK
> 2.3
> > > migrated to FC2?.
> > Most likely the day after the AGTk 2.3 source code is released or has been
> > CVS tagged, I will make a set of AGTk RPMs for FC1 and another set for
> FC2.
> > They will be found where the AGTk 2.3 beta1 RPMs are currently located:
> >     http://www.itee.uq.edu.au/~agn/ag_fedora/FC1/stable/
> > > > After the Fedora AGTk 2.3 RPMs are released, there may not be any
> > > > future RPMs made for FC1 (which uses python 2.2.3),  as python 2.3 is
> > > > now being used on the 3 ANL supported platforms. FC2 is safe, as it
> > > > comes with python 2.3.3.
> > Cheers,
> > Doug
