[AG-TECH] AGTk 2.3 BETA Released
    Fred Dech
    fdech at uchicago.edu
    Mon Aug  9 19:22:10 CDT 2004
ok, Tom.
i'll dig up that log file and bugZit tomorrow.
--fred
On Mon, Aug 09, 2004 at 06:19PM, Thomas D. Uram said:
> You didn't jump the gun.  This looks like a credential (or
> credential-handling) problem.  You should file this as a bug, and
> include your VenueServer.log file to help us determine what happened
> during credential init.
> Fred Dech wrote:
> >i jumped the gun.  i guess that the [--configfile=CONFIGFILE] arguement is
> >now required.  when i add that, to the command line everything's fine.
> >--fred
> >On Mon, Aug 09, 2004 at 05:04PM, Fred Dech said:
> >>hi Doug.
> >>i just noticed this when i started up the venue server:
> >>sucag1(fdech)13% /usr/bin/python2 /usr/bin/VenueServer.py
> >>bound to port  8000
> >>bound to port  8006
> >>Traceback (most recent call last):
> >> File "/usr/bin/VenueServer.py", line 127, in ?
> >>   main()
> >> File "/usr/bin/VenueServer.py", line 89, in main
> >>   venueServer = VenueServer(server, app.GetOption('configfilename'))
> >> File "/usr/bin/VenueServer.py", line 273, in __init__
> >> File "/usr/bin/VenueServer.py", line 461, in LoadPersistentVenues
> >> File "/usr/bin/VenueServer.py", line 729, in AddVenue
> >> File
> >> "/sandbox/agtk/dist-20040809_102253/lib/python2.3/site-packages/AccessGrid/Venue.py", line 379, in __init__
> >> File
> >> "/sandbox/agtk/dist-20040809_102253/lib/python2.3/site-packages/AccessGrid/Security/Role.py", line 195, in AddSubject
> >>AccessGrid.Security.Subject.InvalidSubject
> >>i thought it might be an imcompatibility with earlier .cfg and .dat files,
> >>but i removed them and still got the same messages.
> >>--fred
> >>On Mon, Aug 09, 2004 at 05:55PM, Douglas Kosovic said:
> >>>The Fedora Core 1 & 2 AGTk 2.3 beta1 RPMs can be found at:
> >>> http://www.itee.uq.edu.au/~agn/ag_fedora/
> >>>If you were previous using yum with the AGTk CVS snaphots, then you will
> >>>need to modify:
> >>>   /etc/yum.conf
> >>>Similarily for rhn-applet and up2date, the following file will need to be
> >>>modifed:
> >>>   /etc/sysconfig/rhn/sources
> >>>The modifications involve changing instance of  'unstable' to 'stable'.
> >>>The unstable folders will continue to contain AGTk CVS snapshots.
> >>>Doug
