[AG-TECH] Node Setup Wizard problems
Mike Weaver
weaver at er.doe.gov
Wed Apr 14 11:55:56 CDT 2004
This worked for me! I'm assuming it was the process of deleting and
then re-importing all of the certs.
Thanks Lewis!
Mike
----- Original Message -----
To: "Randy Groves" <randy.groves at boeing.com>
Cc: <ag-tech at mcs.anl.gov>
Sent: Wednesday, April 14, 2004 11:17
Subject: Re: [AG-TECH] Node Setup Wizard problems
> hi Randy,
> try this route, it worked out here ok:
> a. go to each machine in turn, and run the venueclient as a personal
> node (VenueClient.py --personalNode). If any cert request wizards pop
> up, cancel them (over and over) til they go away. you need each venue
> client to run cleanly as a personal node without grumbling - that
should
> mean all certs and IDs are good, and proxies are fine on each unit.
you
> should get a local log on all three machines to let you know whats
> occuring. if you need to, reimport IDs and certs from the
> Venue Client > preferences > Manage Certificates menus
> You can check they are all Ok there also. Only ANL issued certs and
IDs
> are anygood in the longterm. Importing other CAs and IDs doesnt
totally
> work last we tried. Take some time to check all cert parts. The
> default ID, a globus CA and ANL CA cert are needed, and should be
> imported in sequence (globus CA , ANL CA , then personal cert).
> If you reimport - try removing all the older IDs and reimporting. I
> keep a floppy to hand with both CA certs and my trusty ANL ID for this
> tasks. Paranoid maybe, but a good clear out works wonders 9/10 times.
> (By the by - it is very vital you export a safe, known good copy of
your
> ID for later use and retrieval).
> when each machine runs venue client with personal node services
cleanly,
> you can set up the wider multimachine options. I would not try too
much
> further til this step works, and you can start VenueClient with
personal
> node services on each unit manually.
> Also, dont waste time 'managing' your node yet (adding services etc)-
> all those parts change later.
> You should not at this stage be running any other tools manually. No
> command line Node services or Ag service managers - just the
> VenueClient.py with the --personalNode option. try to get away from
> older AGTK thinking - theres a lot of differences, largely
undocumented
> (sorry Ivan, but there is ;)
> b. choose a machine that your users will typically start the toolset
> from. (Almost always this is the display PC). This machine will
> continue to run :
> Make sure the shortcut or script file includes this option.
> Never attempt to manually script AGServiceManager or
> NodeManagementService etc to run on this (the lead) machine - always
let
> the VenueClient start personal node services as needed for you (it
will
> actually start AGServiceManager and NodeManager(?) for you).
> c. On all other machines, set AGServiceManager to run as default
through
> whatever scripting system you want to use. Only AGServiceManager is
> needed. Its best to create long proxies on these machines for this
> reason, as these services will rarely be used interactively later. No
> command line options need be specified.
> d. With AGServiceManager running on the slave machines, start up
> VenueClient --personalNode on your lead machine.
> e. Chose the
> VenueClient > preferences > Manage my node
> option, and the node managment app should pop up. by default the
> localhost will be in there with little else. you should be able to
choose
> Service manager > Add..
> from the menu and add the other two service managers by IP address.
> (Only AGServiceManager.py needs to be running on these to make this
> choice work).
> f. If you get this far successfully, and have three service managers
> listed, you are home and dry. Add/remove and edit your services as
> required across all three machines. when you are happy, choose
> File >Store Configuration
> from the Node Management app.
> You can choose the default configuration, and check use as default,
and
> all your changes should stay put, for all users of the machine.
> In future, always boot all three machines. make sure AGServiceManager
> runs as standard on the two slave units. On the main lead unit,
simply
> run VenueClient with personalNode services enabled - on windows just
> click the desktop shortcut, as --personalNode is already included in
that.
> The personal Node charaterisation is a bit of a misnomer in this for
> sure, but no one sees it. And this way the config stays put over
> reboots and correctly starts required services on each unit
automatically.
> Other routes will see your config and services choices disappearing
> after reboots (if you get that far) and its a right work up.
> Hope this helps get you going sooner rather than later, or at least
> shakes something concrete loose to debug.
> bye
> lewis
> Lewis Grantham LLB MSc
> Project Leader
> Media Resources (Multimedia Unit)
> Windeyer Building
> Cleveland St
> London
> W1T 4JF
> Tel:0044(0)2076799258
> Fax:0044(0)2075800995
