[AG-TECH] Node Setup Wizard problems
    Mike Weaver
    weaver at er.doe.gov
    Tue Apr 13 14:34:27 CDT 2004
I ran NodeManagement.pyw (Windows display machine) and get "Error adding
service manager" when choosing Add... from the ServiceManager menu.
Tried "Manage My Node" from the VenueClient and nothing came up.  This
is after a fresh re-install on the display machine.  The agns & agsm
logs are still empty.  I've attached all logs found in "C:\Documents and
Settings\<ME>\Application Data\AccessGrid".
Thanks, Mike
----- Original Message -----
To: "Mike Weaver" <weaver at er.doe.gov>
Cc: <ag-tech at mcs.anl.gov>
Sent: Tuesday, April 13, 2004 15:16
Subject: Re: [AG-TECH] Node Setup Wizard problems
> Hi Mike:
> Can you try configuring your node using NodeManagement.py?  This
should
> provide additional info about the problem you're having, possibly
within
> NodeManagement itself, and probably in the log files (agns.log,
> agsm.log, AGService.log).  This way, you can get your node set up, and
> we can understand the problem that the node setup wizard is running
into
> and fix it.
> Let me know what happens, and send your log files along if things
don't
> work out.
> Thanks,
> Tom
> Mike Weaver wrote:
> >I installed all prerequisites and AGTK 2.1.2 on my room node
(Display:
> >Win2K, Audio:RHL 7.3, Video: RHL 7.3) and imported my certificate to
all
> >3 machines.   I ran AGServiceManager.py on all machines and then
> >NodeSetupWizard.pyw from the (W2K) Display machine.  When it tries to
> >connect to the Video Capture machine, it fails.  All systems are
> >time-sync'ed and DNS-resolvable (each can ping the others).  All
certs
> >(Globus & ANL CA and my ID) look fine on machines.
> >I see the AGServiceManager running on the video machine and tcpdump
> >shows traffic in both directions when the display machine attempts to
> >connect, but it still fails.  The agsm.log file on the video machine
is
> >empty even with the --debug option.  The agsm.log file on the display
> >machine is also empty.  The NodeSetupWizard.log on the Display
machine
> >says:
> >04/13/04 12:32:52 1728 AG.NodeSetupWizard nodesetupwizard.pyw:332
INFO
> >NodeSetupWizard:VideoCaptureWindow:Validate: Service manager is not
> >started
> >Any advise would be appreciated.
> >Mike
> >Mike Weaver
> >Sr. Network Administrator
> >SC-31/Germantown Building
> >US Department of Energy
> >1000 Independence Avenue, SW
> >Washington, D.C. 20585-1290
> >Voice: 301-903-0072
> >Fax: 301-528-2701
> >Email: weaver at er.doe.gov
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040413/17903227/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040413/17903227/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040413/17903227/attachment-0002.obj>
