[AG-TECH] Re: VideoProducerConsumerService
Brian Corrie
bcorrie at sfu.ca
Thu Apr 8 18:44:33 CDT 2004
Hello all,
I sent this email to the list last week, but never saw it on the list
itself so I thought I would resend it... Did anyone see this or did the
zip file cause it to be filtered somewhere... I have attached the
individual files this time instead... Just put them in a zip folder and
follow the directions below.
Enjoy,
Brian
Brian Corrie wrote:
> Hello all,
> I just finished creating a new AG service that is quite useful for a pig
> node. Neither the VideoProducerService or VideoConsumerService are
> terribly useful for a pig node as the settings for neither are correct.
> The producer does not have unmuted video and the consumer does not
> transmit on startup and has low quality and bandwidth settings. This is
> an extension of the VideoProducerService that currently exists that both
> transmits video at startup as well as has all of the video
> sources un-muted.
> If anyone is interested, give it a go. We have tested under windows and
> Linux. I have been using it on my desktop for some time now and it seems
> to work fine - not to surprising at it didn't change much... 8-)
> If you want to install it, just copy the attached file (the ZIP folder)
> into C:\Documents and Settings\All Users\Application
> Data\AccessGrid\services folder. Under Linux you just put the folder in
> /var/lib/ag/local_services. You should be able to go into Manage My
> Node and see it listed when you try and add a service. You can then
> remove the old video service and add the new one. Voila!!!
> Enjoy,
> Brian
> p.s. If the zip file gets stripped out by virus filters let me know and
> I can resend...
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040408/0b8b9190/attachment.diff>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040408/0b8b9190/attachment-0001.diff>
