[AG-TECH] Idea for a feature
Colin Perkins
csp at csperkins.org
Tue Sep 30 08:05:31 CDT 2003
On Tuesday, Sep 30, 2003, at 12:52 Europe/London, Robert Olson wrote:
> At 03:45 PM 9/29/2003 -0400, jski at blargh.wpi.edu wrote:
>> I was noticing that there is a quite a range of volume levels in use
>> by the
>> various nodes/PIGs etc. What if there existed a service or
>> application,
>> bound to the test room that would tell you when your volume was set
>> correctly. It would be sort of like being able to look at the VU
>> meters in
>> RAT at the remote location. If everyone were able to set their level
>> against
>> a standard meter then there would be less of a problem of too much or
>> not
>> enough volume when you got into a meeting. You also would not require
>> a
>> remote node to test with every time you changed a setting (yes, we
>> still
>> need the test runs to make sure...) Could be handy for initial
>> settings.
> You can do a lot of this yourself by targetting your send levels to be
> peaking at the top of the green in rat (the rat meters are a fairly
> absolute scale).
Correct - the value you see in your VU meter in rat is exactly the same
as the value the receiver sees.
Colin Perkins
http://csperkins.org/
