[AG-TECH] Direction of communication with a Virtual Venue Server
shudo at ni.aist.go.jp
Fri Sep 26 10:48:10 CDT 2003
Hi Bob,
Thanks for your quick reply.
Now, I tried to use the TVS (https://vv2.mcs.anl.gov:9000/Venues/default)
again and succeeded to connect to it!
I cannot guess the reason why I couldn't achieve it.
> At 12:12 AM 9/27/2003 +0900, shudo at ni.aist.go.jp wrote:
> >I suppose AGTk 2.x needs establishment of TCP connections initiated by
> >a Virtual Venue Server and it is the cause of the problem I'm facing.
> >I guess it because the AG node can use a VV server that I run locally
> >on the inside of our firewall.
> >Is this correct? If so, it's natural that AGTk 2.x do not work in our
> >network configuration. And I have to ask our network administrators
> >to change the configuration of the firewall.
> The AG client should, for all of the basic functionality, make only
> outgoing connections. Things that won't work are lead/follow and personal
> data on the client behind the firewall.
> Are you able to ping the venue server from your machine? Which venue server
> were you trying to contact?
> --bob
