[AG-TECH] MOO communication ports
Brian d'Auriol
bdauriol at cs.utep.edu
Mon Sep 22 11:00:21 CDT 2003
A local port scan might help, are you on windows? if so, I use the
freeware active ports found
on http://www.ntutility.com This software reports on the local processes
which have opened ports. It is easy to download and install. Hope this
helps.
Brian
(Computer Sci. UTEP)
On Mon, 22 Sep 2003, Alson Been wrote:
> Date: Mon, 22 Sep 2003 11:20:15 -0400
> From: Alson Been <beena at cookman.edu>
> To: Ag-Tech <ag-tech at mcs.anl.gov>
> Subject: [AG-TECH] MOO communication ports
> Hello all,
> Does anyone know if there is an in bound port that is used by the MOO
> client? I know port 7777 is out bound which is allowed, but for some
> reason I am not able to connect going through a PIX firewall and doing
> static NAT. Is there a way to identify from the client which ports are
> being used? Any thought on this?
> Thanks
> _______________________________________
> Alson Been
> Bethune-Cookman College
> 640 Dr. Mary McLeod Bethune Boulevard
> Faith Hall Annex A02
> Daytona Beach, FL 32114-3099
> Phone: 386-481-2336
> Fax: 386-481-2023
> Suncom: 8-378-2336
> E-mail: beena at cookman.edu
> Check out our home page: www.cookman.edu <http://www.cookman.edu/>
