[AG-TECH] dppt
Russ Wolf
russ at bu.edu
Fri Sep 19 09:53:19 CDT 2003
This all has to do with microsofts settlemet with Sun Microsystems and
the removal of Java from their operating systems. The ddpt works if you
have installed WinXP Service Pack 1 - the currently available version i
1a which does not contain the JVM.
If you install the Sun JVM it will still not work since Sun's Java does
not support the Microsoft specific COM calls that ddpt uses to work.
You need to get the Microsoft JVM.
If people want I believe I have a copy of the original SP1 for WinXP to
work.
And it should not matter which verison of Office you have - except that
OfficeXP introduced something that changed the COM stuff and Office2000
did not bother with.
We work fine with The Latest patches to both WindowsXP (using SP1) and
OfficeXP.
-Russ
Paul Mercer wrote:
> George
> Yes. To get make dppt work we installed it on the node op's personal
> laptop, XP with office XP and it worked just fine.
> Paul
> At 12:53 PM -0500 9/18/03, George Estes wrote:
>> I should add, on XP not W2K.
>> At 12:36 PM 9/18/2003 -0500, Robert Olson wrote:
>>> Have folks been able to use dppt on office xp at all?
>>> At 10:28 AM 9/18/2003 -0700, Michael Gates wrote:
>>>> I too had this problem on a freshly installed/patched machine with
>>>> XP pro
>>>> and Office XP. I uninstalled Office XP and installed Office 2000
>>>> and it
>>>> started working again. If I had to guess, I would say that it was a
>>>> patch
>>>> to Office XP that broke it.
>>>> Hope it helps,
>>>> -Mike
>>>> On Thu, 18 Sep 2003, Paul Mercer wrote:
>>>>> Bob
>>>>> Our main, room size, node worked fine. We have used dttp for a long
>>>>> time without any problems. Until last Friday, when our problem was
>>>>> noticed, it had been several months since we had used dppt. Do you
>>>>> know of a potential conflict in running Win 2000 with office XP or
>>>>> maybe one of the patches, from microsoft, is causing the problems?
>>>>> Our laptop pig is experiencing the same thing. The pig is a recent
>>>>> build. Dppt was never used until we tried it a couple of days ago.
>>>>> Paul
>>>>> >At 04:32 PM 9/17/2003 -0800, Paul Mercer wrote:
>>>>> >>All
>>>>> >>Our dppt has stopped working on two machines. Both are running
>>>>> >>Win2000 with office XP ,all ugrades and patches are current.
>>>>> >Did it stop working after one of these patches by any chance?
>>>>> >As you say it stopped working, it had been working previously on
>>>>> >these computers?
>>>>> >--bob
>>>> Michael Gates
>>>> VTC Services
>>>> mgates at sdsc.edu
>>>> 858.864.3841
>>>> Room 109
