[AG-TECH] AGN Audio Lip Sync
Randy Groves
randy.groves at boeing.com
Tue Sep 16 13:36:21 CDT 2003
How much, if any, would the local machine time vs. the remote nodes' time
have to do with this? Would it help to make sure that NTP is running and
appropriately syncing the system time?
-randy
At 08:04 AM 9/16/2003, Brian Corrie wrote:
>When a lip synch is noticed, always the first solution is to restart rat. It
>does tend to drift over time. The size of the drift in the time you mention
>seems rather large. That is a bit odd. We see this occasionally if we leave
>things on over long periods of time, but it is certainly not consistent (we
>don't seem to degrade as a direct function of time).
>I am not sure why the sync slippage occurs (don't know enough about rat/vic
>and the RTP encoding) so I can't diagnose why you are seeing what you see.
>The only thing that pops into my head is that if there is packet loss it may
>have some impact (the protocols are supposed to handle that, but...). Also,
>computationally, if the vic or rat processing can't keep up and falls behind
>this may be the culprit. I can't remember if we see lag in the video or in
>the audio in our case. With UDP and RTP, one would think that this would not
>happen (you would just see packet loss instead) but again I am not sure...
>That probably didn't help much did it 8-)
>Brian
> > -----Original Message-----
> > From: Wachtel, Robert L [mailto:Robert.Wachtel at mso.umt.edu]
> > Sent: Tuesday, September 16, 2003 7:23 AM
> > To: ag-tech at mcs.anl.gov
> > Cc: Christensen, Scott A
> > Subject: [AG-TECH] AGN Audio Lip Sync
> > Are there any recommended solutions to the following audio video
> > synchronization difficulty?
> > Symptom: A progressively increasing sync delay between the video and
> > audio received from other sites within a venue. Lip sync is very close
> > when initially entering a venue, and then consistently the audio is
> > progressively delayed behind the video. After an hour uptime we can
> > notice a difference of up to 3 seconds. If we kill and
> > restart just the
> > rat, the sync will be restored and then begin slipping again.
> > System:
> > AGN 1.2
> > Audio Box: Monarch AMD dual processor 4GB RAM, Creative Audigy sound
> > card, Red Hat Linux 7.3 OS
> > Video Display: Monarch AMD dual processor 4GB RAM, Matrox G450 x4 MMS
> > quad head display card, Windows 2000 Pro OS
> > Local Network:
> > 100Mb Switched to desktop
> > 1Gb Campus backbone
> > Any suggested solutions or additional diagnostic measures would be
> > appreciated.
> > Thanks,
> > Bob Wachtel
> > Director
> > Presentation Technology Services (PTS)
> > The University of Montana
> > Missoula, MT 59812
> > Phone: 406-243-2857
> > FAX: 406-243-2689
