[AG-TECH] AG2.1.1 and RH 9
Todd Zimmerman
todd.zimmerman at newmic.com
Tue Sep 9 12:16:58 CDT 2003
Hi Michael,
To find the file you can do a search at rpmfind.net for libssl.so.2 or
libcrypto.so.2 (the required libraries) - or just follow this link
http://www.rpmfind.net/linux/rpm2html/search.php?query=libssl.so.2&submit=Sea
rch+...
The actual name of the rpm I installed was openssl096b-0.9.6b-3.i386.rpm
Todd Zimmerman
Research Assistant - NewMIC
New Media Innovation Centre
Ph: 604.806.5100
> -----Original Message-----
> From: Michael Miller [mailto:mimiller at ncsa.uiuc.edu]
> Sent: Tuesday, September 09, 2003 9:38 AM
> To: ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] AG2.1.1 and RH 9
> Todd,
> When I searched for "openssl096b-0.9.6b-3.i386.rpm", I didn't find
> anything. And given my lack of experience with RH linux 9
> and the number
> of openssl packages to choose from, I want to make sure I
> install the right
> one. Can you clarify which package you installed?
> thanx
> Michael Miller
> NCSA
> At 11:08 AM 9/9/2003, Todd Zimmerman wrote:
> >Hi Chris,
> >We currently have a couple of AG2.1.1 installs on RH9 and
> everything appears
> >to be working fine. In fact we are currently testing a
> VenueServer and
> >BridgeServer on RH9 and that also appears to be ok.
> >The only issue I had was the pyOpenSSL issues. AG2.1.1
> required libssl.so.2
> >and libcrypto.so.2 which are provided in the
> >available at rpmfind.net. Once that is installed, I just
> ran the install
> >script and all seemed to ge good.
> >Todd
> >Ph: 604.806.5100
> > > From: Osland, CD (Chris) [mailto:C.D.Osland at rl.ac.uk]
> > > Sent: Tuesday, September 09, 2003 3:17 AM
> > > Subject: [AG-TECH] AG2.1.1 and RH 9
> > > As an "I second that" can I ask the list whether they think that
> > > RedHat 9.0 is a suitable base for AG 2.x.x?
> > > Our systems people have suggested that by the end of this year the
> > > only supported RedHat may be RH 9, so we have just installed that
> > > on the capture and audio machines, prior to installing AG 2.x.x .
> > > Indications from elsewhere are that some bits of the
> system, possibly
> > > just the servers, are unhappy with anything later than RH 7.3 .
> > > Before expending the effort on installing AG 2.x.x, I
> would therefore
> > > like to check which base people think is best (RedHat
> only, please).
> > > In a similar vein, our current display machine is Windows
> 2000, and
> > > I am assuming that it is sensible to move to Windows XP
> for AG 2.x.x;
> > > any views on this?
> > > BTW, we are doing the migrations by having alternate caddied hard
> > > drives for the different systems, keeping the rest of the hardware
> > > the same.
> > > Cheers, and thanks in advance
> > > Chris
> ____________________________________________________________________
> > > Chris Osland Office tel: +44 (0)
> 1235 446565
> > > Digital Media and Access Grid Medialab tel: +44 (0)
> 1235 446459
> > > BIT Department Access Grid room tel: +44 (0)
> 1235 445666
> > > e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0)
> 1235 445597
> > > CLRC Rutherford Appleton Laboratory (Bldg. R18)
> > > Chilton, DIDCOT, Oxon OX11 0QX, UK
> > > [The contents of this email are confidential and
> > > are for the use of the intended recipient only.
> > > If you are not the intended recipient do not take
> > > any action on it or show it to anyone else,
> > > but return this email to the sender and delete your copy of it.]
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your
> team with
> clear objectives, they will invariably do their best to
> achieve everything
> desired, and usually deliver everything you could have hoped
> for and even
> more." -Paul Debevec
