[AG-TECH] pyOpenSSL Source RPM
Todd Zimmerman
todd.zimmerman at newmic.com
Fri Sep 5 14:04:32 CDT 2003
Excellent - Thanks!
Although... for the sake of others experiencing the same problem, I solved
the RH9 dependency issue by installing the
openssl096b-0.9.6b-3.i386.rpm available at rpmfind.net (which supplies
libssl.so.2 & libcrypto.so.2)
BTW, just wanted to thank all of the developers & ppl working on AG2.1.1 - it
looks great!
Thanks again,
Todd
Research Assistant - NewMIC
New Media Innovation Centre
Ph: 604.806.5100
> -----Original Message-----
> From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> Sent: Friday, September 05, 2003 11:47 AM
> To: Todd Zimmerman
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] pyOpenSSL Source RPM
> Todd:
> The links have been fixed and the source rpms copied into the space.
> Tom
> Todd Zimmerman wrote:
> >Hi All,
> >Could someone fix the link to the pyOpenSSL_AG-0.5.1-3
> source rpm. I need
> >the source rpm to fix the RH 9 pyOpenSSL dependancy problems...
> >The link is at this website:
> >http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/r
> eleases/2.1.1/re
> >dhat.html
> >It _should_ link to
> equired/SRPMS/py
> >OpenSSL_AG-0.5.1-3.src.rpm but I get a 404 instead.
> >Actually, it appears that the pyGlobus rpm source is missing also.
> >Thanks!
> >Todd
> >Ph: 604.806.5100
