[AG-TECH] FW: automatic transmit in vic & talk in rat
Todd Zimmerman
todd.zimmerman at newmic.com
Wed Oct 29 11:47:48 CST 2003
Hi Denise,
Colin Perkins offered a solution on the AG-Tech list a couple of weeks ago
(thx Colin!), and it worked for us - see
http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2003/10/msg00098.h
tml
Basically, in unix you add the following line to your $HOME/.RATdefaults
file:
*audioInputMute: Off
For Windows, you can supposedly add it to the registry.... but I haven't
tried that (yet!).
Todd
Research Assistant - NewMIC
New Media Innovation Centre
Ph: 604.806.5100
> -----Original Message-----
> From: Denise Runnels [mailto:Denise.Runnels at usm.edu]
> Sent: Wednesday, October 29, 2003 9:32 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] FW: automatic transmit in vic & talk in rat
> We need to do automatic video transmission in vic and
> automatic talk in rat
> upon startup in order to make both tools more user-friendly.
> For vic, I've found the solution by using a command line option
> with the attached tcl script. That is, "vic -u script.tcl ip/port".
> For rat, I didn't find a command line option to do automatic talk.
> I've traced the source code down to one line. Inside the
> rat-4.2.23/rat/ui_audiotool.tcl file, if we change the flag in
> "set in_mute_var 1" to 0, it should do what we want.
> Is there an easier way to deal with the automatic talk in RAT
> without having
> to recompile the code?
> Thanks,
> Denise
