[AG-TECH] (newbie question) AGTk 2.1.2 certificate problem
Dioselin Gonzalez
dioselin at purdue.edu
Mon Oct 27 03:18:16 CST 2003
I installed AGTk 2.1.2 on a single machine node with Windows XP. I
followed the installation instructions but when I run Request
Certificate, it won't do anything. I see the hourglass cursor for a
while but then it does nothing. When I run the venue client, I get the
following error and then it hangs:
Application object creation failed
ASCII encoding error: ordinal not in range (128)
The venue client cannot continue
Attached is the log file.
Any help would be appreciated.
Thank you,
Dioselin.-
Dioselin Gonzalez.-
Graduate research assistant
Envision Center for Data Perceptualization at Purdue
http://www.itap.purdue.edu/viscenter/
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031027/64d238c1/attachment.diff>
